Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 11-03-2005, 06:36 PM
  #1771
Aurra Sing's Avatar
Default re: spool chatter
I lube the pins on the driveshaft quite a lot, keep them clean, and rebuild the CVDs often, and I do not experience any chatter.
EDIT: oops, I thought this was the Pro4 thread.. but should be the same once I pick up my HB around Christmas time can't wait
Aurra Sing is offline
Old 11-04-2005, 12:13 PM
  #1772
Buyer Beware
my cyclone should be here on Monday....
HELLOkitty is offline
Old 11-04-2005, 01:03 PM
  #1773
rc-zombies's Avatar
that's great...Have fun building it... should take you approx. 3hr.45min.23sec. to build... not including chassis prep.
rc-zombies is offline
Old 11-04-2005, 01:07 PM
  #1774
Buyer Beware
WOW!
you know the precise time it will take....any ideas on which motor,esc,servo,body,etc to get for this car?
Old 11-04-2005, 01:10 PM
  #1775
rc-zombies's Avatar
WOW!
same electronics that's on my car...
Old 11-04-2005, 01:12 PM
  #1776
Buyer Beware
hehehehehehehe
Old 11-06-2005, 10:33 AM
  #1777
belgianchamp's Avatar
Hi,
I have a question:
My friend snapped 4diffscrews from his pro4, anybody also has this problem?The diffs are very smooth not tighten to much and when he hits something not hard its finished.Somebody nows what the problem can be?
belgianchamp is offline
Old 11-06-2005, 12:02 PM
  #1778
Skill's Avatar
I know someone who had a Pro 4 who broke about 5 diff screws in the space of about 4 months. Personally I've been racing with the Pro 4 and now Cyclone for over a year and a half and have never broken one [touch wood].
Skill is offline
Old 11-06-2005, 03:41 PM
  #1779
Hi, I have only ever broken one, and that was because I had the diff done up silly tight cause the grip on the track was so high. Under normal conditions I have never broken one. I know quite a few people who have Pro 4's who have not had problems though. Try replacing all the other diff components at the same time as the nut next time as there may be another bit that is faulty or built incorrectly. Jonathan
jonny69 is offline
Old 11-06-2005, 06:34 PM
  #1780
tc3 racer sc's Avatar
some one plse tell me when the diff coming out for cyclone so i can run carpet thxs
tc3 racer sc is offline
Old 11-06-2005, 08:24 PM
  #1781
ngo8's Avatar
i just finished building mine for thrust bearing i used the TC4 one works perfect the hotbodies/hpi was out of stock and i just bought 2 bearings instead of one and 2 spacers .
ngo8 is offline
Old 11-07-2005, 01:25 AM
  #1782
bretthitman's Avatar
Default page
on page 12 on the the cyclone manual at the top of the page ware the misprint is about the spur gear and the pulleys is page 31 the correct way it should go toughter can any one help thanks brett
bretthitman is offline
Old 11-07-2005, 03:54 AM
  #1783
JoeyE's Avatar
Trader Rating: 45 (100%+)
Go do your homework Aurra!
JoeyE is offline
Old 11-07-2005, 05:38 AM
  #1784
tir
so to reduce the chatter I need to widen the pin slot on the spool...and also install the RDX or Xray pin plastic pin blades...?
No, I would not advise widening the pin slot. Blades do not stop chatter..
Chatter will only be observed in reality when the wheels are free floating on the bench.
When on the track the actual inertia in the car will be sufficient to combat the observed chatter - there of course still remains oscillation variations but it does have a negligible effect on the cars overall performance. The result of the increased vibrations will really only manifest themselves in premature wear, slight understeer and slightly reduced corner speeds but equally this has to be offset against the cost and reliablity of proper constant velocity joints for RC cars.
No matter what car you drive the most important factor in getting the most out of the car is to concentrate on making sure that the transmission is as clean and free running as possible and for that matter as light as possible. Binding belts, sloppy joints, poorly fitting A arms etc will have a more detrimental effect on the cars overall performance than the oscillation problem. Then of course there is the fact that we need to make sure we hit the right lines at all times. These will cost us seconds per lap - oscillations will cost us 000's of a second...
tir is offline
Old 11-08-2005, 07:42 AM
  #1785
Guo Chean's Avatar
hey does anyone runing cyclone with front spool and middle one way? if i using this setting will it be possible to used break too??? so what you guys normally tighten the rear diff will it be loosen or tighten it very tight using front spool in order to get good handling?? thanks
Guo Chean is offline
