new ofna DM1 pics and thoughts :):)
#1111
#1113
#1115
6.1 lbs 360mm
#1117
Ofna gtv2 aka team c
#1118
Do u know when they comin out?
Edit
Never mind $540 @ tower mid nov
Edit
#1119
Where is all the weight in the dm1 and what's the lowest anyone ever had the car weight wise.
#1120
#1123
Thanks....Ok im thinking on keeping the dm1,but im thinking about getting rid of the pivot balls and going to a regular buggy a arm set up.If i do what buggy a arms could i go with and do you guys think it will shave some of the weight on this car.
#1124
You can use Jammin buggy suspension parts. May require some mods, and a SNR hinge pin holder. It has C-Hub suspension.
Sorry I don't have an idea on weight savings
#1125
My DM-1 has almost all that can be done to it to lighten it. I will try to find how much it weights. I still have the pivot ball susp but I changed it to Mugen Ti balls (or even the Mugen factory ones are lighter). Also you can change the steering hubs to the Mugen and save some more. You will need to use either Mugen or AE steering plastic linkage that are bent (they look like a hockey stick). This because the stock ones will rub on the wheels. While you are at it you can change the steering link to Ti as well. I used RC8 Ti turnbuckes, you can use these in front and in the rear.
