#4713
with they program box connected to the computer i right clicked on the HW screen,there was about 4-5 diffrent options came up,one will be administrator
change that so you are they admin and it will then allow up dates.
then click on 2 in 1 program box,select soft ware.were it says choice version you then need to change that to what ever 119 version you want from the drop down box
#4715
have my own questions regarding boost/turbo
my current set up (given to me as a starting point for my car/track)
fw 211
boost 20
turbo slope 24 units .1 sec
turbo 20
boost start 5000rpm
turbo delay .1
timing acc/slope 500 rpm-unit
does this mean my boost starts at 5,000rpm,every 500 rpm 1 deg of timing is added,so by 15,000 rpm all 20 deg of boost is added ?
if at this stage throttle is at 100% for more than .1 of a second the turbo timing kicks in and because i have a turbo slope of 24/.1 it will dump the 20 deg of timing in .1 of a second ?
just want to understand how it all works
fw 211
boost 20
turbo 20
boost start 5000rpm
turbo delay .1
#4716
fw 211
boost 20
turbo 20
boost start 5000rpm
turbo delay .1
fw 211
boost 20
turbo 20
boost start 5000rpm
turbo delay .1
#4718
#4719
i would like to personally thank angelo for all his help on sorting out my xtreme esc issue...i owe you one......if anyone has any issues or questions do not hesitate to ask him......he has always been helpful on more than one occasion for me.....keep up the good work.....
#4720
Angelo we need it the new firmware , ???? bored
#4721
i was thinking i mite get on they Microsoft forums and start bugging bill gates
for a firmware up grade. it would be the "irgo ignore" version 1.1
basically if you run this new up grade it automatically deletes any posts by irgo.
or maybe it could be called the "parrot remover"
"irgo wants a rpm logger" "irgo wants a rpm logger" "irgo wants a rpm logger"
"irgo wants a rpm logger" squawk squawk "irgo wants a upgrade" "irgo wants a upgrade" "irgo wants a upgrade" squawk squawk
#4725
