Durango DEX210 Thread
#8011
Bulletproof ballcup
I found a video somewhere that shows how to make the inner rear ballcup secure. After buying the Tresrey rear camber mount, I threaded some button head screws into the trans case. After checking several times for clearance, I locked everything down. Now, the inner-rear ballcup can't pop off. These inner cups were the ones that poped off every time out on the track during my first trip to the track with this car.
I also installed the Cream shock towers on the front and rear of my car.
#8013
Only trouble I had building the kit was the O-rings under the shock caps. They kept trying to fold and push out before getting the shock cap tight.
I put shock oil on the o-rings but they still wanted to fold and push out. I just kept tighten a little then push the o-ring in, tighten a little, push o-ring in, etc.
Hopefully these won't cause issue. Shocks feel ok right now but haven't been on track with it just yet.
#8014
#8017
#8019
Good to hear that. I built mine according to the Tips and Tricks on Durango's sight. Used a drill to run the turnbuckles in and out the ball cups about ten times. They seem real easy to adjust, and hope to hit the track today if I get finished with my daughters agenda in time. I feel there will be no pop off problem.
#8022
