Durango DEX210 Thread
#7996
Like these...
There are others, but you get the idea.
#7997
Azagar mentioned something I've thought for a while; can the number of piston holes / size be offset by the weight of the oil? Seems to make logical sense; but maybe other factors come into play that I'm not thinking about
#7998
To a point, yes. You can get the same static damping on the bench with heavier oil and more holes. You can even get it to handle very close to the same around corners for the most part, but you can't get the pack of less holes (unless you had smaller holes like .9mm-just a guesstimate to make the point). If you have some coming, I suggest plugging a few holes for the time being to get close to what you'll eventually have.
#7999
I have been seeing a lot of carbon front shock towers for the 210 and noticed that several of them convert the inner camber ball studs to horizontal (stock is vertical) and was wondering how this affected the geometry. To make the ball studs horizontal, they would have to push them further out (forward) on the chassis from the stock position.
Anyone have any experience with any these towers?
J
J
#8000
Thought you guys would like this. New CF battery hold-down for 210.
http://www.tresrey.com/tresrey/products/tytd126.html
#8001
#8002
Ok, don't laugh now, but I never assembled a bladderless shock before; should the shock cap's o-ring be placed in the cap prior to assembly, or on the shock body below the threads before assembly?
#8005
Rear tower, Rear hubs, rear gearbox case (especially if you upgrade ball cups). Those are the only thing I have broke.... I would build the car with a carbon steering rack. Thats IT!!! This buggy is bombproof!
#8006
Thanks Atomicsickness
#8007
OK, so I figured "why not" give the carbon tower a try.
We will see how it works, all I am out is a little time so I started with the truck and cut a carbon tower.
I know it is the truck in the buggy thread, but if it works I will design and cut a buggy one also.
I still need to clean up the holes a bit and ca the edges but it fits great.
J
J
#8009
Saw this on the Tresrey Blog!!! Not interested in the battery holder. I am interested in this black, milled out chassis!!! Murdered!!
Attachment 974989
Attachment 974989
