Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 09-12-2007, 08:28 PM
  #3931
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by mo
I just measured a front wheel bearing on my TC5 and it is 3mm thick. The manual is correct.
Just got a bearing kit in and can confirm that. They are 6x10x3mm. Losi makes a bearing that will interchange in a pinch also...just blew one and used Losi bearing to replace.
Verndog is offline
Old 09-12-2007, 09:03 PM
  #3932
smostyn's Avatar
Trader Rating: 9 (91%+)
That is such a relief. I have been looking everywhere for 6x10x4 and I can find VERY few of them and they are VERY expensive.
6x10x3 on the other hand are everywhere!
Thanks guys.
smostyn is offline
Old 09-12-2007, 09:30 PM
  #3933
smostyn's Avatar
Originally Posted by kn7671
Heck, if we want to go there, the AE TC5 manual states the wheel bearings are 6x10x3mm bearings, but they are actually 6x10x4mm.
Actually, my manual says 6x10x4
smostyn is offline
Old 09-12-2007, 10:31 PM
  #3934
Weasely's Avatar
Ive done a bit of a search across various boards looking for something but not had a ton of luck - Running in a newly assembled car - what can be said about that? I made sure to keep the diffs real loose on the first run, and have been gradually tighening them since. I still dont really know how tight is appropriate.
What else should i know, or is that basically it?
Weasely is offline
Old 09-13-2007, 03:09 AM
  #3935
Trader Rating: 16 (94%+)
Doh! I knew what I meant, I wrote it backwards. The manual states 6x10x4mm bearings, they are actually 6x10x3mm. Sorry guys, but you all confirmed it, the manual is wrong. I already asked this question directly from AE support on their website; my post and AE's response is out there. AE confirmed it to be a misprint.
kn7671 is offline
Old 09-13-2007, 03:59 AM
  #3936
RAP66's Avatar
diff setting is in the manual... if I recall toghten all the way down then back off (loosen) 1/4 turn
RAP66 is offline
Old 09-13-2007, 06:14 AM
  #3937
Are you racing carpet foam? If so, I run 1/4 loose in the rear, 1/8 turn loose in the front. The standard setting is 1/4 loose front & rear, but I want more drive coming out of the corner, which a tighter front diff will do.
kn7671 is offline
Old 09-13-2007, 07:41 AM
  #3938
Trader Rating: 12 (100%+)
TC5 spools and aluminum outdrives are available!!!!!!
yle00984 is offline
Old 09-13-2007, 09:46 AM
  #3939
Turbonium's Avatar
Trader Rating: 27 (100%+)
any idea where? i looked on tower and stormer, my typical sources, and nothing there... yet.
Turbonium is offline
Old 09-13-2007, 10:57 AM
  #3940
RC MARKET's Avatar
which part no. ?
RC MARKET is offline
Old 09-13-2007, 01:26 PM
  #3941
sonic31's Avatar
Trader Rating: 6 (88%+)
wasup everyone, i'm looking for the titanium racing spool for the tc5 but unfortunately can't seem to find it here in florida,usa if anyone knows where i can get it overseas or here please post it here or pm me ... thanks.
sonic31 is offline
Old 09-13-2007, 03:47 PM
  #3942
Originally Posted by JuhoL
Does the toe change if you flip the hubs from side to side? Are they new hubs? I havent seen any new hubs that arent right so far. Sometimes you bend them in big crashes though. The holes are molded and not drilled so they should be pretty accurate.
Also make sure the arm mounts are not backwards?
Nope, nothing is backwards and the rear hubs are both the same, at least with the 0 degree ones. Not sure if it changes once you start using optional 1 or 2 degrees though.
As for bending them, nope. I was just setting it up on my bench at home when I noticed the ridiculous difference in toe! I hadn't even got the car on the track yet.
Anyhow, that all being said, I drove it last night with the wonkey shim setup and it's fine. I ordered some parts for it to see if the new ones are any better but I'll drive it as is until I break it.
Another note, this thing has insane steering! I used to run my dual rate at 75 with my RDX and I had to change the setting down to 35 for the TC5! I also had to reduce my rear droop quite a bit. I'm probably only running about 1mm of droop, although I am going to increase it slightly now that I'm a little more used to it. And this is all with a mostly stock setup and RUBBER tires! Kit chassis, kit springs, no sways, and a one-way. I love it!!!
TurboT is offline
Old 09-13-2007, 04:44 PM
  #3943
Verndog's Avatar
I'd have to say your servo horn is too long. I went thru the same thing until I was able to "level" out the steering turnbuckle. If your running a Futaba servo then Dubro makes a horn kit that has one just the right length. With a one way and the correct length, I'm at 78% on my dual rate after setting my EPA (set with dual at 100%) just before steering hits the stops.
Verndog is offline
Old 09-13-2007, 06:35 PM
  #3944
i ordered it Directly from Team Associated!!!
yle00984 is offline
Old 09-13-2007, 09:16 PM
  #3945
STLNLST's Avatar
Trader Rating: 32 (100%+)
same here. I thought that mine would be here today so hopefully it comes tomorrow or else I will have to put the car back together with the original equipment. I have the top spool as a back up though. Good thing I'm really good friends with the guy running TOP USA
STLNLST is offline
