Tekno RC SCT410.3 Thread >
Like Tree219Likes
    Hide Wikipost
Old 09-05-2022, 08:19 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC SCT410.3 Thread
Last edit by: rustyus
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 – V2 Adjustable Hinge Pin Brace “A” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 – V2 Adjustable Hinge Pin Brace “C” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B – HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 – Hinge Pins (inner, front/rear)
TKR5516 – Front Suspension Arms and TKR5515 – Rear Suspension Arms
TKR5542 – Spindle Carriers - TKR5541B Spindles
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Use steering stops/limiter washers... more info here.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Hinge Pin Insert Chart:
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 07-03-2016, 07:58 AM
  #3901
Does anyone still run a trackstar system? not seeing much from searching the thread. Wondering is a 4850 with a 15 t pinion on 2s with the trackstar 120a ESC would work or would that overheat cause of the 4850 motor
http://www.hobbyking.com/hobbyking/s...dproduct=56264
http://www.hobbyking.com/hobbyking/s...Truck_ESC.html
caffeine357 is offline
Old 07-03-2016, 09:05 AM
  #3902
Kremzeek's Avatar
I don't see why not. The specs say that the ESC will work with motors 6000KV or less on 2S. If it were me, I'd start with a 14T pinion though.
Kremzeek is offline
Old 07-03-2016, 07:52 PM
  #3903
yeah everyone seems to run a 4030 tekin so i want to make sure if i get the 4850 that i dont have too much with the pinion to smoke the motor.
Old 07-04-2016, 12:26 AM
  #3904
Furthermore, im getting ready to order everything for my truck, any other upgrades i need to pickup before i build it? I saw a few people recommend the A block i think
Old 07-04-2016, 06:30 AM
  #3905
Do i need to buy a servo horn for a new build like I did for my ebuggy build?
Old 07-04-2016, 06:47 AM
  #3906
It comes with a plastic servo horn, most people upgrade to aluminum though. Not necessarily needed for the build though.
deceit is offline
Old 07-04-2016, 07:09 AM
  #3907
JoeRC123's Avatar
I bought the Tekno aluminum arm. Then I found out my Protek servo came with an aluminum arm. The Tekno one was pretty nice so I ended up using it.
JoeRC123 is offline
Old 07-04-2016, 07:19 AM
  #3908
I would get the aluminum servo horn. I would also get the aluminum diff pins.
The next upgrade for me would be the shocks. Aluminum bottom nut and delrin inserts.
Some people don't like the lighten star wheel hexes. As long as you don't overtighten the set screw, I think it's fine.
qstorm777 is offline
Old 07-04-2016, 08:45 AM
  #3909
Sounds good,ill get the aluminum servo horn. thanks guys
what about the A Block upgrade
http://www3.towerhobbies.com/cgi-bin...?&I=LXFGAZ&P=M
and by the aluminum pins do you mean these?
http://www3.towerhobbies.com/cgi-bin...?&I=LXEKWA&P=7
Do I assume it comes with plastic hexes? cause there are these as well.
http://www3.towerhobbies.com/cgi-bin...?&I=LXDNYG&P=M
Old 07-04-2016, 08:56 AM
  #3910
Are the aluminum diff pins just for better wear? I never heard anything bad about the composites.
And would you recommend the delrin inserts on a new kit?
deceit is offline
Old 07-04-2016, 07:11 PM
  #3911
The kit wheel hexes are steel. Some people have tighten the set screw too much breaking the hexes. I would initially stick with the kit wheel hexes.
I would definitely upgrade to aluminum a block.
Those are the aluminum diff pins. Some people have broken the plastic diff pins. That's why I recommended the alum diff pins. I never ran the plastic diff pins - I went straight to the aluminum.
The delrin inserts are smoother than the stock shock inserts. It's not a must. It does improve performance though.
Old 07-05-2016, 04:30 AM
  #3912
JoeRC123's Avatar
Just use a little loctite on the set screw for the stock hexes and snug them up. Not too much. Works great.
JoeRC123 is offline
Old 07-05-2016, 07:00 AM
  #3913
Hey Guys,
I just picked up my new Tekno SCT410.3! I need a little gearing help. I am swapping over the electronics from my Slash 4x4. The motor and ESC are a Castle 2650kv and a Castle Sidewinder 8th ESC. I eventually plan to get a Tekin Setup but for now this is what I have. I run this setup on 3s and I am wondering what you guys think a good pinion to start with is?
Thanks for any help!
stanton120 is offline
Old 07-05-2016, 07:12 AM
  #3914
DirkW's Avatar
Originally Posted by stanton120
Hey Guys,
RPM should be comparable to a 4000kv on 2S... so, depending on track size... somewhere around 17T (+/- 1) pinion, would be my first guess.
DirkW is offline
Old 07-05-2016, 08:29 AM
  #3915
Wont they bust him for being overpowered? that is going to run crazy fast. hell, go 18 tooth! ahaha
twistedneck is offline
