TLR TEN-SCTE 2.0 Kit Thread
#4066
What parts from the 1.0 can be used as spares for the 2.0
#4067
#4069
with all the chat about the 2 hole shock set up what's the benefit of this newb here. What do I need to do to apply this 2 hole setup. Part # would be great
#4071
Sam do your self a favor buy the 2.0 kit is going to cost you way less if you try to save money by piecing the kit is going cost you more , maybe less but not by much , if you are anything like me im very picky i would be wanting to upgrade here and there so here you are , spend the the same or more if you would have allready bought the 2.0 from the very beggining believe me i`ve done it myself I spent more then I needed if I would have just bought the kit from the very beggining LOL
#4072
#4073
Has there been report of any other plastic parts shrinking besides the lower shock caps? I bought a losi 2.0 kit NIB from another person and the lower shock caps were shrunken and it also seems that some of the plastic parts that have 1/16th screws are REALLY hard. I have striped one of the diff screws and one of the servo mount screws, and all the other servo mount screws and diff screws have worn heads. I even got a brand new 1/16 high quality wrench and a screw still stripped out. I would contact Horizon about it but as I bought it from another person I have no receipt.
#4074
#4075
Tech Prophet
The lower shock cap was an issue from a long time ago but never really picked up as the shocks were assembled with power tools at the factory and they did not have an issue using the tooling they had to get them one. Once they ended up in kits they identified the issue and corrected it.
#4077
With a lot of people testing different setups, has anyone tried stiffer rear springs? Just curious, if anyone has, how did it effect the handling of the truck?
