TT-01 Forum
#2402
Ah, OK. I tried white springs in the front, but the dampers would stay fully extended because the low car weight. My car will hopefully be even lighter soon with a light weight body and a thinner paint job than my usual "let's just empty a can on this shell to get it done quickly" technique.
Hugo
Hugo
#2404
Is it a sensored brushless? If not, there is your power delivery problem. I drove a 13.5t sensorless, plenty of power but too much punch. The brushed Cup Machine is easier to handle because power delivery is more smooth.
Hugo
Hugo
#2405
Oh, and did you free up your bearings and gears?
http://www.youtube.com/watch?v=gCinjfeACRA
Hugo
+ YouTube Video | |
Hugo
#2406
It's sensored, the car rolls freely, and I'm surprised it's that fast! With an FDR of 5.11 running a 17.5, I didn't think it'd reach such a speed. I tried a 13.5 in the car; it would get up to 35mph before the stock kit tires and poor aerodynamics of the Beetle couldn't handle the speed and the car would spin out. Guess I'll lower the gear ratio and enjoy the car for what it is, and leave the high performance to my other cars.
#2407
YR Aluminum Front Upper Arm
Anyone tried out this option to get camber?
#2408
#2409
I have the plastic Tamiya ones, but for racing the stock non adjustables do well. These to me are more bling than function.
Cheers,
Hugo
Cheers,
Hugo
#2410
Thanks HugoW, cleaned my bearings and I could feel and see a difference.
Question, will the TRF Short Works dampers work on the TT-01? If so, what will the ride height be and will there be enough travel on the dampers
#2411
We had/have a TT-01 class here that only allows Tamiya upgrades. All of the really fast guys are running the TRF short (M series) shocks. It's really the only way to get down to 5mm ride height.
#2412
Hi guys,
I'd like to fit the better axles to my racer, the 53792:
But I use the wide wheel adapters, so these axles are too short. There of course is an easy solution, but I cannot find it...
Cheers,
Hugo
Cheers,
Hugo
#2413
Hi guys,
Cheers,
Hugo
Cheers,
Hugo
#2414
Is there a number on those? They sell them in all lengths. 48mm, 50mm, 52mm.
I get them from TQ RC.
#2415
The number is there, 53792. They are 48mm as per the TT standard, but I want the axles sticking through the wheels to be long enough so I can place the wider wheel adapters, the little hex pieces locking axle rotation to the wheel.
Cheers,
Hugo
Cheers,
Hugo
