Team Losi JRXS Type-R >
Like Tree52Likes
Old 05-24-2009, 01:33 PM
  #9631
Radron's Avatar
Trader Rating: 36 (100%+)
Congrats Dragonfire!!
Looking forward to seeing your set-up.
Radron is offline
Old 05-24-2009, 03:21 PM
  #9632
Radron's Avatar
Please help a JRXS-R sedan noob here...
I"m going to be running 13.5 rubber/asphalt & foam/carpet & I"m trying to find out gearing for both so I can order gears.
I was told with a 108t 64p spur, I would need to be in the low to upper 50's on pinion,but when I try to calculate it. I come up with high 30's to mid 40's. Am I doing something wrong? What would you seasoned drivers suggest I be starting at?
Thanks for your time, Ron
Radron is offline
Old 05-24-2009, 03:25 PM
  #9633
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Radron
Please help a sedan noob here...
go to: www.gearchart.com
choose you car and enter the spur and pinion you want and it will make a chart for you.
yyhayyim is offline
Old 05-24-2009, 03:38 PM
  #9634
Radron's Avatar
Thanks, that's where I'm getting my #'s.
My problem is, I don't know for sure what pinion I want. I just want to make sure I'm doing this right. I don't want to order a bunch of gears & find out I'm wrong.
Can someone confirm I'm in the ballpark or way off.
Thanks, Ron
Radron is offline
Old 05-24-2009, 03:44 PM
  #9635
yyhayyim's Avatar
Thanks, Ron
Ok...
108 spur/ 52T pinion= 3.80 Final Drive
108 spur /50T Pinion= 3.95
For outdoor rubber tire racing, you'll probably want to be in the 3.7-4.0 range.
Here's what you'll need to buy: get 104 & 108 Spur gears. For pinions try from 50-53. That will cover you pretty much from asphalt to carpet.
yyhayyim is offline
Old 05-24-2009, 04:10 PM
  #9636
Trader Rating: 21 (100%+)
Originally Posted by yyhayyim
Ok...
On the car that the car that he is getting already has a 108 on it. He needs pinions between 50 and 55.
lidebt2 is offline
Old 05-24-2009, 04:15 PM
  #9637
Radron's Avatar
Thanks guys.
Yea blue in your e-mail you said 59 & I just couldn't get that to calculate.
My roll-out was just to far off.
Thanks again guys, I'm off to order some gears now
Radron is offline
Old 05-25-2009, 01:09 AM
  #9638
Heres what I ran for the weekend.... I had TQ stiched up on the 1st day so I tried some other ideas for the 2nd days qualifying so I could see if I could improve but they simply didn't compare.
Dragonfire is offline
Old 05-25-2009, 01:14 AM
  #9639
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Originally Posted by Pablo Diablo
Congratulations to Dragonfire who today won the Much More Masters in Sydney. This is one of the biggest on road events in Australia and there were plenty of big named drivers competing, but it was Dragonfire with the little known Losi, who TQ'd and took the win.
That's fantastic. Its ALWAYS great to see a type R on top.
Great job bro.
a_main_attendee is offline
Old 05-25-2009, 07:04 AM
  #9640
YmeBP's Avatar
Trader Rating: 32 (100%+)
Gonna try this out with my 4.5. Is that droop written as "4", "0", or "9"?
YmeBP is offline
Old 05-25-2009, 07:06 AM
  #9641
Pablo Diablo's Avatar
It would be 4.
Pablo Diablo is offline
Old 05-25-2009, 06:40 PM
  #9642
jrxs-r's Avatar
Trader Rating: 11 (100%+)
Dragonfire and Pablo Diablo--> Thanks for the help and support over the weekend at MMM. I really appreciate it. If I can do anything to return the favour, just yell! Had a good time there!! Love your driving too... the A3 Final was a hoot to watch...
I personally have 2 of Pablo's layshafts in my hand, and they are a work of art. Didn't manage to get them in the car over the weekend of racing at MMM, but I've put them in for the local club racing to see how they go. Dragonfire's setup will require a smooth throttle finger, as well as a smooth wheel hand. I got a bit lost on setups on the Saturday of qualifying (lack of sleep and ultra epic brain fade) and I tried Dragonfire's setup and it kind of worked well enough for me to qualify 9th in the A. I have since gone up to a 20lb front spring and a .060 swaybar in the front to deaden the steering a little for my style of driving. I'm pretty ham-fisted....
jrxs-r is offline
Old 05-26-2009, 11:22 AM
  #9643
metalracer2's Avatar
Trader Rating: 20 (100%+)
pablo diablo
when do you think your lay shafts will be avalible in the us i really want to get one or two
metalracer2 is offline
Old 05-26-2009, 06:28 PM
  #9644
Sorry I am generally not a neat writer. My droop is 3mm over front ride height and 4mm over rear. Depending on grip level going up one rate on front spring or down one rate on the rear should give a more driveable car with only a minor loss of steering.
Old 05-26-2009, 07:07 PM
  #9645
C.Poh's Avatar
couple questions. i am going to be running on a indoor carpet track and want to run rubber tires, are the Jaco prism green or blue compound the way too go and what set up do i go with some one told me go with the asphalt setup with rubber tires even on a carpet track true or false ?? also i am running the excelorin speckuntrol with the trinity 8.5 motor and trinity 3800 lipo,is the gearing that comes with the car ok, the manual says 128t 29-31 pinion,or is this gearing way off and the car wont be any fun to drive.. thanks..
C.Poh is offline
