Spec-R R1
Old 11-29-2012, 03:41 AM
  #451
spencehotbodies's Avatar
Hello guys
Spec r have a load of spares in stock now.
spencehotbodies is offline
Old 11-29-2012, 08:20 AM
  #452
Xenolance's Avatar
The xray spring steel outdrives are confirmed to work in this Spool FYI, I just got some and they fit perfectly.
Part number: SPR020-SCXR
Xenolance is offline
Old 11-29-2012, 08:36 AM
  #453
Trader Rating: 84 (100%+)
just so everyone knows i have been runninig a complete xray spool in my car and it is the same as the r1 except better quality. so yes any drivetrian parts for an xray will drop right in the r1 as it is the same.
jeff jenkins is offline
Old 11-29-2012, 09:03 AM
  #454
PitNamedGordie's Avatar
Good to know...are you using the Xray DCJs also?
Have you noticed any difference in the two? Or are you using the Xray out of personal preference?
PitNamedGordie is offline
Old 11-29-2012, 10:05 AM
  #455
I was using it cuz my stock one stripped out as I for some reason forgot to put screws inside the spool cups. But I do notice you don't need shims for.the xray one as its a better fit.
Old 11-29-2012, 12:45 PM
  #456
Xenolance's Avatar
Yes, I'm running Everything x-ray up front. The front spool cups, DCJ's, etc. All of it's a direct drop in and of course the xray stuff is slightly better quality. The Spec-R DCJ's are a great improvement over the stock CVD's for sure! I only run 17.5 blinky so the springsteel spool cups are really not needed, but they are pretty :-)
Mostly I'm just trying everything I can get my hands on to test them out and see what fits. I'm going to try some Aluminum hubs/knuckles tonight, the local guys have several different cars so I get a bit of variety in parts..when they actually have spares that is.
Like Jeff said, the x-ray spool is better quality as far as the fit and finish but the one I have seems a bit heavier..not that it's enough to ever be noticed.
Old 11-29-2012, 03:14 PM
  #457
SteveM's Avatar
Trader Rating: 165 (100%+)
My S1 is built and rigged and I'm just finishing off the body tonight. Another light coat or two of white to back the colours and I should be done.
SteveM is offline
Old 11-29-2012, 03:32 PM
  #458
Really like that paint! Very 90's
Bappe is offline
Old 11-29-2012, 09:17 PM
  #459
AdrianM's Avatar
SteveM - That looks like a Parma Alfa. That body was great on foam tire but is very low steering for rubber tires.
AdrianM is offline
Old 11-30-2012, 02:56 AM
  #460
Darrin70's Avatar
R1 build is complete, testing saturday.... S1 build underway!!!!
Attached Thumbnails Spec-R R1-img00430-20121124-1436.jpg   Spec-R R1-img00448-20121126-1357.jpg
Darrin70 is offline
Old 11-30-2012, 03:20 AM
  #461
SteveM's Avatar
Yup...it is the Parma Mohawk (Alfa) for sure and was a body I had kicking around. I painted it just to have a lid more than anything else and to try the Faskolor paints. I wanted something retro looking and I think I managed that OK. It should be fine for practice to break in the S1. The paint is old school for sure, but then again I'm old so it works.
I used a cheap small paint brush to dip into the paint and then flicked it onto the shell. I used about 12 different colours and let them dry overnight before backing with white. I don't have the decal sheet and I'll have to hand paint the grill and headlights after it's trimmed and mounted. The good thing is nobody else at the track will have anything like this.
SteveM is offline
Old 11-30-2012, 05:20 AM
  #462
Big Midget's Avatar
Trader Rating: 101 (100%+)
Is that a box stock S1 build?
Looks like a carbon fiber chassis plus other up grades?
Big Midget is offline
Old 11-30-2012, 05:53 AM
  #463
Xenolance's Avatar
LOL, he says it's the R1 build he did.
The S1 build hasn't started yet.
Old 11-30-2012, 06:08 AM
  #464
Hear and read a lot all over the place about the built and performance of the R1.
Could someone please provide me with a resume as to the issues I have to look after when building this car, problems, alterations, other hick ups and so on?
Preferably with solutions (partnumbers if and when parts are needed)
Many thanks.
I am on a very tight budget. So I can't afford it to buy me the car not knowing what is gonna hit me and come to the conclusion that I can't finish it because of my lack of expertise and/or lack of cashflow as to buying additional stuff to make it work.
Again thanks for the effort.
Kensei is offline
Old 11-30-2012, 06:51 AM
  #465
Xenolance's Avatar
Many thanks.
See my review:
http://www.rctech.net/forum/11448187-post359.html
It covers pretty much everything you asked for. It's the S1 review but it's the same for the R1 for the most part.
Only must have's IMO is:
Protek R/C Ceramic 5x8x2.5mm Metal Shielded Flanged "Speed" Ball Bearings (2)[PTK-MF85ZZC] These can be found at amainhobbies.com
.2, and .3mm Shims. these need to be 3x5x.2 shims to fit M3 size screws. No real part numbers I know of. I use these:
http://www.reflexracing.net/RSD-Stai...cs_p_1254.html
Other than that there are no "Must have" items. The bearings I listed fix the lay shaft issues with the kit's included shims. The .2MM shims will fix the slop in the steering rack and chubs if you are really worried about it. You may want to find some .1MM shims in the same size just in case your kit is tighter than mine.
