Spec-R R1
#467
See my review:
http://www.rctech.net/forum/11448187-post359.html
It covers pretty much everything you asked for. It's the S1 review but it's the same for the R1 for the most part.
Only must have's IMO is:
Protek R/C Ceramic 5x8x2.5mm Metal Shielded Flanged "Speed" Ball Bearings (2)[PTK-MF85ZZC] These can be found at amainhobbies.com
.2, and .3mm Shims. these need to be 3x5x.2 shims to fit M3 size screws. No real part numbers I know of. I use these:
http://www.reflexracing.net/RSD-Stai...cs_p_1254.html
Other than that there are no "Must have" items. The bearings I listed fix the lay shaft issues with the kit's included shims. The .2MM shims will fix the slop in the steering rack and chubs if you are really worried about it. You may want to find some .1MM shims in the same size just in case your kit is tighter than mine.
- these fit without problems/alterations? http://www.spec-r.com/default/index....roducts_id=322
- what about drilling the holes in the shock pistons?
- drilling the shock caps? (for example 1mm)
- on petit rc it is said to use anti wear grease. I really don't know which one. Maybe you have a partnumber?
- other fine tuning issues?
(gonna get me TA green slime for the geardiff and the shocks)
Thanks again.
#468
-Mike
#469
Thanks!
Thanks again.
Thanks again.
Yes, those DCJ's fit without modification, they are what I'm currently using.
Drilling the pistons isn't necessary. the kit gives you two and three hole pistons and the three hole seem to be working perfectly at my local track. they are 1.1mm holes I think. It's really personal preference and any standard 10mm piston should work. I use the RSD Soft shock bladders as they are more consistent than the stock Spec-R units and just seem to react better.
http://www.reflexracing.net/RSD-10mm...ers_p_528.html
Drilling the shock cap is only if you want zero rebound. I used the shock rebound tool and put it on the lowest setting and did not drill the caps, they seem fine and very consistent and this is largely personal preference, track surface and driving style oriented.
Anti-wear grease is something along the lines of associated black thrust bearing grease. Associated P/N: ASC6588]
http://www.amainhobbies.com/product_...ack-Grease-4cc
Green slime, also known as SF3 grease, is always a good idea. I also heard a tip that Kyosho ORG03 P3 Orange O-rings are much better preventing shock "Squeak".. I'm trying them out but didn't get to race last night on them due to poor conditions. (never buy Green slime from associated! it's a HUGE rip off! a tub of the EXACT SAME grease that is 300X the amount of a single tube of green slime is only $5.Link below)
Xray drive train components work in this car just fine, the spool in the front is the same size so if you want a slightly better quality spool you can buy the X-ray unit. but really I see no point as it's slightly heavier and you'll not break the spec-R spool if you remember to put the screws in it unlike some joker on here
http://www.amainhobbies.com/product_...g-P3-Orange-10
http://shop.noleenj6.com/product.sc?productId=8
#470
http://www.speedtechhobbies.com/inde...lter_name=shim kit&product_id=214
http://www.amainhobbies.com/product_...lutch-Shim-Set
http://www.amainhobbies.com/product_...all-Bearings-2
Are these instead of the spur gear shaft bushing SPR-R1P310?
If so, then two are needed? Do these wear down fast? I mean should I buy more than one set of two?
#471
Ok, so my car turned up finally after sitting in customs for over a week :-/
Built it yesterday, no major concerns at all apart from as jeff mentioned, the layshaft is miles off with regards to shimming, I must have measured about 1.2mm extra endfloat. But that is easily shimmed out, or in my case I think I'm just going to make up some new bushes that the layshaft sits in to take up the slack.
Also the hubs with the top hats feel like they needed a shim in too.. Like you have on the TCX etc between the top hat and the c hub.
I too had to add 0.1mm spacers to the upper bulkheads to avoid pinching.
Basically the car went together very simply, just be sure to have some of the correct sized shims available when you do the build.
All in all a nice piece of kit and I can't wait to give it a run in the next few weeks.
Pictures of unboxing and build in my blog link below
Which LiPo and what does it weigh?
Can't seem to find that info in your specifications.
Would a 5400mAh LiPo be sufficient for 13.5T and SP Cirtix ESC?
Only reason why I would opt for this LiPo (from CS) is because of its weight.
Thnx
#472
It's all detailed in my blog, which is linked from Petit RC, and below in my sig.
I use MooreSpeed 5600 lipo's.
With the car you really don't need to worry about the weight, I had issues finding where to put it to get up to minimum limit.
#473
80/35 4,343
80/36 4,222
80/38 4,000
74/40 3,515
But that wouldn't work than?
If so which spurs and pinions to use to these FDR's?
Like to know before spending money on these.
Thnx
#474
Edit: Oops didn't realise many people used 48dp anymore lol
#475
Ah crap on second thought I know the math to convert it.
The smallest spur/pinion I was able to use for an FDR of 3.4 was an 86T/48T, 64P. This is a 65T/35T spur in 48P so never go smaller than that.
The 74T spur you mentioned is about a 99T in 64P. This will give you a lot of flexibility in gearing but is kindly big for my tastes.
I would do a 72T spur (96T 64P) and 39 Pinion for 3.5FDR and just stick with that spur to get the smallest spur/pinion you can. If I did the math correctly the smallest pinion you can use with the 72T spur is a 28T pinion. (86+10=96, 48-10=38, the smallest pinion you can run with a 96T spur is a 38T pinion. 38/2*1.5=28.5, You have to round up to get the correct pinion size so that means it's rounded up to 29T so this give you 2 additional teeth to work with since you can go down to a 28T pinion.)...Gods I hate math..
72/30=4.56
72/31=4.412
72/32=4.27
72/34=4.023
72/39=3.507
Wow.. that was confusing for me and I'll bet I'm wrong somewhere in all that crap up above!
I hate switching spurs myself but the combos you listed will all fit just fine if you really want to switch spurs to get your gearing more exact. I use 64P since it's easier to dial in the exact ratio using a single spur gear.
#476
I've not tried 48p so I'm of no use, Sorry!
72/30=4.56
72/31=4.412
72/32=4.27
72/34=4.023
72/39=3.507
72/30=4.56
72/31=4.412
72/32=4.27
72/34=4.023
72/39=3.507
So mine would work?
But yours is more handy because there is no need for switching spurs?
I hope this spur and these pinions are available. Gonna look into it.
You say you bet you are wrong somewhere? I hope not............
#479
I just double checked the math on mine and it appears to be correct.
If you want to do the math the formulas are as follows.
Convert 48P to 64P: (X/1.5*2=Y) where X is the tooth count in 48P and Y is the tooth count in 64P, Example: ( 72/1.5=48, 48*1.5=96 ) So this shows that a 72T spur in 48P is the same size as a 96T spur gear in 64P.
Convert 64P to 48P: (X/2*1.5=Y) where X is the tooth count in 64P and Y is the tooth count in 49P, Example: ( 96/2=48, 48*1.5=72 )
So in my example, 65/35 was the smallest combo that would fit giving a FDR of 3.52 but you could never go smaller than a 35T pinion.
To get the smallest you could use with the 72T spur you simply subtact 65 from 72 which is 7. Then subtract 7 from the pinion size, so 35-7=28 which is the smallest pinion you should be able to run with a 72T spur.
Wow I really hate math and gear ratios. I wasted around $50 USD trying to find the best ratios I could for this car and I've always liked the smallest spur/pinion combo I could get away with as the car always felt more responsive that way.
#480
So I thought I was going to test out some emulsion shock caps so I ordered the tamiya 501 x shock caps and turns out they do not thread onto the shock body. Bummer. But I did put in tamiya shock shaft and the tamiya grooved o-rings and the shocks feel extremely good now. And I am using the RSd bladders.
Luke, what shock caps were you going to try.
