Losi XXX-S
How are you guys mounting the Tamiya shocks to the PRP towers? I talked to a guy and said Tamiya has a ball nut?? But have not been able to find them. ANy help?
My HERO!! How about here in the states?
You're killing me.
Ask Speedworld to order you some TAM53599 (I think). Speedtech RC also has them (although they're out of stock right now).
I just got some blue alluminum ball-nuts for my Evo off of SpeedtechRC not too long ago....If theyre out of stock e-mail Steve and he'll probably get some for you
Is it generally a good idea to run a one-way on a rather small track. It is 80 x 50 ft.
carpet of asphalt? If carpet, NO. If asphalt, probally. There is no set answer to that question.
Here ya go...
53599 Flourine Coated 5mm Aluminum Ball Nut (Silverish 10pcs.)
53640 5mm Aluminum Ball Nut (Blue 10pcs.)
53641 5mm Aluminum Ball Nut (Red 10pcs.)
53539 Aluminum Spacer Set (to space the ball nuts away from the shock tower)
All of these use 3mm screws
Yeah, it is an asphalt track.
gtypecanare- you are awesome. Thanks
Please explain the racing diff between these.........
Blue belt
Yellow belt (thats the one I use now for stock racing)
Black belt
Thanks in Advance
Blue belt
Black belt
Thanks in Advance
XRC cars Touring Car Head to Head comparison
I just read XRC Cars Magazine Touring Car Head to Head comparison in its current issue. (Only belt driven cars)
Quite an extensive test, including 3 drivers and three days of Racing.
Bottom line; they gave first prize to X-Ray. Losi XXX-S G+ tied with Tamya for second.
What hurt the XXX-S was the fact that it did not come with a one-way.
The constant complaint over 3 days and 3 drivers was lack of steering. They all said the XXX-S was stable and easy to drive and had lots of straight line speed and stabilty.
They spoke of adjusting all the cars after their first and second day but complained that they could not get rid of the XXX-S understeer. This confused me, I thought you could always adjust a car to have more steering by scarificing in some other area.
also, understeer seems to be my biggest problem with the car ... I am not sure my setup is really optimum and I know my driving is not.
Blue belt
Black belt
Thanks in Advance
Blue belt
Black belt
Thanks in Advance
huuuummmm ---- which "blue" belt
Blue belt
Black belt
Thanks in Advance
Blue belt
Black belt
Thanks in Advance
The black belt and the new blue belt (not available yet) are what you want. They both utilize a new longer tension arm that eliminates the radical belt wrap of the old shorter arm (comes with RTR and G+ kit). This frees up the drive train significantly. You want that.
