Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 05-12-2008, 12:59 PM
  #12271
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Lazer Guy
I ran a 4600kv (more then a 10.5=4200kv) on carpet so I left it in to try your setup and get my asphalt legs on again.
The 7700kv on paper is between the 4.5 and 5.5, I ran the 7700 all last year. On the track it runs with a good 4.5 when geared right. Both my Mamba max's have tremendous mid-band HP witch makes them unpredictable in TC's as stated by rcenut123. I run my low end up and it helps smooth out the mid-band. My 7700 will pull away from the 3.5's and 4.5's coming onto a strait but the 3.5's will pass me on the long straits.
really
STLNLST is offline
Old 05-12-2008, 06:52 PM
  #12272
ASM
ASM's Avatar
Trader Rating: 30 (100%+)
STLNLST, what insert are you guys using the 36's? Thanks.
ASM is offline
Old 05-12-2008, 06:53 PM
  #12273
Originally Posted by STLNLST
really
Really and I did not get a T-shirt ether
Lazer Guy is offline
Old 05-12-2008, 10:57 PM
  #12274
STLNLST's Avatar
right now we are running the premounts from speedmind but when I glue up my own then it's all Hara inserts
If no shirt then some stickers???????????
STLNLST is offline
Old 05-13-2008, 05:52 AM
  #12275
I'm going back to our standard set up. It was consistent and always kept me in the hunt for the win. I tested alot of set up's in two days and find myself sticking with the regular.
I know you race mod but I'm not sure what the tracks you race on are like. Do you think the standard set up will work on a layout with many tight turns???
I think I have that set up sheet but I,m not sure it's the one you are using.
Old 05-13-2008, 09:44 AM
  #12276
wikedgmc's Avatar
Trader Rating: 76 (100%+)
which Hara inserts are you using? The medium or the firm, version 1 or version 2?
thanks
wikedgmc is offline
Old 05-13-2008, 10:12 AM
  #12277
Where are people getting the hara inserts from?
Tony Vega is offline
Old 05-13-2008, 01:42 PM
  #12278
STLNLST's Avatar
I'd give it a try. It worked on Speedworld's big track in mod and worked on a smaller track in 19/10.5 Did i send you the set up via email? If so then that's what I'll be running this weekend.
thanks
Hara firms and I'm using version 1. They seem to feel the sorex tire better.
I got all of mine over seas last year. I bought a ton of them and with us running mostly handout tire's (RIP RP30's) it took me a while to go through them. I do have to find me a new source for them.
STLNLST is offline
Old 05-13-2008, 05:12 PM
  #12279
No I did not get it from you so it must not be the same one, If you would, send it to me, I would appreciate it.
Thank you
Old 05-13-2008, 07:09 PM
  #12280
Has anyone managed to get a hold of the new arms?
Interested to see if the slightly softer rear shock position yields good results, as the HPI suspension is always firmer in the rear end.
Besercoe is offline
Old 05-14-2008, 08:55 AM
  #12281
RC MARKET's Avatar
Trader Rating: 12 (100%+)
The rear upright had toe-in problem !
RC MARKET is offline
Old 05-14-2008, 12:10 PM
  #12282
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Cyclone for sale...get a second......
rcarmchl is offline
Old 05-14-2008, 12:23 PM
  #12283
revo61's Avatar
Trader Rating: 18 (95%+)
Questions??
I only use lipo and a 10.5 brushless. Where do you guy place weight to get your car legal? I have to add at least 300 grams to get my car up to 1525 grams. I have a soft pack SMC 4000 lipo soft pack and planning on getting a hard pack 4000 lipo.
revo61 is offline
Old 05-14-2008, 12:39 PM
  #12284
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
longshot of a question...looking to try to get correct gearing with a 17.5 on my hara cyclone...
but i dont want to switch belts or pulleys or any of that jazz. Lookin at speedtech i can get a 87t spur (if you guys know where i can find smaller spurs that'll work on the cyclone lemme know) and 59+ tooth pinion gears. The huge ass pinions will definately be helpful on attaining the right gear ratio but will it be too big and hit the chassis? Would i have to buy that brushless motor mount kit? That thing is expensive :/
Syber Serulean is offline
Old 05-14-2008, 12:40 PM
  #12285
KHoff7's Avatar
On the sides of the battery until it is balanced, you can also mount weights on top of the battery. When the weight is placed on the side it will give more leverage for balancing without having to add as much physical weight.
KHoff7 is offline
