Team Associated SC5M Thread
#2161
Ran my 1st race with the SC5M last night. Qualified 3 finished 3rd. Had a bad push but also at the touch of throttle the rear end would kick out. Made adjustments and got the rear end not to kick out so bad, still had the push. Today I was looking it over and the diff was way to tight. When I would turn one tire the other tire and motor would turn same direction. I think that was probably biggest part of the problem. What do you guys think?
#2162
#2163
Very slick hard packed dirt. I loosened the diff up just around a 1/16th of a turn and it freed the diff up.
#2164
Any word on the SC6D? I believe it will be called that just guessing.
#2165
Adjustments
I got to run my sc5m for the first time this weekend. I have a couple of questions. What's the internal transmission gear ratio? Is it 2.62? Also i got my suspension feeling pretty good, but i could use a little more turn inwhat could i adjust to get me a little more?
#2167
I don't run an SC5M, but if you need a slight increase in turn-in, you may want to try lowering the front roll center a little bit. Looks like you could add an extra washer under the tower ball studs (for the camber links) to accomplish this.
#2168
thinking of getting one of these and switching from my T5M should I go ahead and buy one or wait for the new one if there is one on the way.
#2170
Right I know there is a lot of similar parts, but I hate to waste the money now for the SC if in a few months there is going to be a 6 series.
#2171
thinking of switching from TLR to AE SC5M. does anyone know how big of a difference the B6 was from the B5 ? only asking because the same changes will more then likely be made to the new SCT.
#2172
When I switch and get one of these are there any needed upgrades that are necessary I don't care about bling just needed parts to improve durability, performance.
#2175
Yes it is for racing only. And I'll be racing shorty batteries instead of square packs because I already have them.
