Hot Bodies D413 1/10 4WD Buggy
#1532
Justin.
#1533
Maybe he's on a small track indoor track, I used to run 10.5 on our track and it was perfect, I'll being trying 17.5 in mine as stock, hopefully I can get enough speed with a 38pinion, if not I think I'll go with the xb4 or zx6 once it's released, fingers crossed though I'll have enough speed cause I like this buggy.
Justin.
Justin.
#1534
The 22 front wheel is slightly narrower. The yellow wheel shown is a TLR-22 front, the white wheel is an HB D413 front.
Ty uses PL #2734-04
http://prolineracing.com/wheels/velo...hite-wheels-22
The reason I chose the 22's offset is because it has a flat dish compared to the typical 4WD wheel which has a convex dish. The convex dish makes the wheel nut stick out further past the tire making it more prone to getting snagged on track pipes/borders. Also when going through tech the max width includes the wheel nuts so with the convex shaped dish you end up with a narrower front track width (center line distance between the two front tires) from the same maximum width (wheel nut to wheel nut).
Ty uses PL #2734-04
Looking at the wheels for the 22/22-4 they don't seem to have a recess for the nut, I'd like to have some recess if possible, how long after kit release will the yellow wheels be available roughly?
Justin
#1535
Overpriced in my opinion. I guess I will get the xray for the same price! I know tower will discount about $40 but it's still not worth that kind of money. I would even go with the sworkz too. Pricing will make a difference for alot of buyers. Look at he new TLR. Alot of folks I know won't touch it because of the price tag. It's a 1/10 scale not an 1/8 scale.
By the time you buy the 2014 xray Xb4 - $439.99 @ Amain and then upgrade the diffs the D413 is a bargain....not to mention the center diff, tunable flex in the arms...and the option to do a couple of different battery layouts.
I'm getting stoked!
#1536
We have just heard back from A Main and they will be carrying the D413, they have them on order. Hobbico is the Distributor for HPI/HB in the US, they sell to hobby stores all over the US.
#1537
If you were to run on a low grip slick indoor surface for example what would be the changes you make to the kit setup before you threw the car on the track?
Any feedback would be greatly appreciated by us guys on low grip tracks.
Cheers Justin
#1538
#1539
Haven't been here for a while and to my surprise this car is still not available. First it was November, then first quarter of the year. Wonder how much sales were lost from these false release dates. And only now it can be preordered for late April, but probably won't be out until mid to late May. Great job. The only thing good about hb is Ty Tessmann
#1541
#1544
How soon can we preorder it
#1545
