Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 03-30-2008, 09:06 PM
  #11626
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
So when is the Hara, or Moore version of the new cyclone coming out?
I want to build me a new car lol
BlackedOutREVO is offline
Old 03-30-2008, 09:46 PM
  #11627
SammyZ's Avatar
Trader Rating: 138 (100%+)
ehhh I wish! but realistically I doubt there gonna release something like that. Muchmore already discontinued all their Limited stuff, chargers, dischargers, power supplies, tire warmers etc.
SammyZ is offline
Old 03-30-2008, 10:05 PM
  #11628
Trader Rating: 23 (100%+)
Default diff trouble
I finally ran into diff trouble this weekend.....nothin but grief at our final series race! Broken screws, mysterious tension loss, all the stuff everyone has been complaining about here for months. Guess it finally caught up to me. Has anyone been running the new diff yet? Is it good? Does anyone have them in stock?
pcar951 is offline
Old 03-30-2008, 10:11 PM
  #11629
Trust me Pcar951, the new pro-spec diff is awesome! super silky smooth action with long lasting.
you won't be disappointed with it.
Hi-LowBlow is offline
Old 03-30-2008, 10:19 PM
  #11630
Well MM stuff was over priced anyways lol, I never cared for there stuff really..
There will be, or atleast a pro level kit (alu turnbuckles, TI parts ETC..)
Old 03-30-2008, 10:20 PM
  #11631
You running the alu out drives?
Old 03-31-2008, 01:32 AM
  #11632
mangoman's Avatar
Trader Rating: 11 (100%+)
I hope you mean titanium turnbuckles!!!!!
mangoman is offline
Old 03-31-2008, 01:11 PM
  #11633
Yes, front and rear for carpet. Tried ceramic and carbide balls in the thrust and diff, sanded washers, the whole enchalada! I even tried to go back to the delrin outdrives....no luck.
pcar951 is offline
Old 03-31-2008, 02:06 PM
  #11634
SammyZ's Avatar
you might have a warp in your outdrive thats putting undue stress on the screw itself! try replacing the outdrives and the screw, then coat the screw in some black grease. Are you using the pro 4 25mm screw or the Ti-coated 27mm?
SammyZ is offline
Old 03-31-2008, 03:55 PM
  #11635
Stew Noble's Avatar
Originally Posted by richard baker
Gents
Im having trouble getting my WCE out of slow corners.
I run Stew Nobles complete setup with sorex 28 tyres indoors on carpet, with SP 10.5 motor, lipo and LRP Sphere TC.
i run CS high grip additive.
It seems if i keep the car rolling its fine but out of slow hairpins or corners where u have to brake, when getting back on the power the rear end steps out like a 2WD. Seems to be due to the torque of the brushless motor.
I have de tweaked the car, all settings are fine as car is superb through faster corners carrying massive corner speed.
Only thing i can think of is the diff feels a bit rough but adjusted correctly?
Help
Richard
Try LRP Carpet2 additive too, but stagger your rear/front application ;)
Stew Noble is offline
Old 03-31-2008, 04:10 PM
  #11636
I'm using the 25mm screw, never had a problem before with it. I tried numerous different outdrive sets as well during qualies.
It's all water under the bridge now anyhow. For the main I threw in a rear diff that I had in another car....problem solved. The issue is, it cost me a spot in the A main in a fairly big regional race. I'll never trust these diffs again so bring on the new stuff!
BTW: with the rear diff working, the Cyclone had over a lap on the second place car in the B.
pcar951 is offline
Old 03-31-2008, 04:12 PM
  #11637
yokemad's Avatar
@Stew
Does Elliot drives 008 now and What are your thoughts about 008 does it worth to go for 008
Cheers
yokemad is offline
Old 03-31-2008, 04:28 PM
  #11638
SammyZ's Avatar
dude no wonder it snapped, the 25mm pro 4 screw is too short! try the 27mm ti-coated one! ive never snapped one with close to 50 runs on it!
SammyZ is offline
Old 03-31-2008, 06:37 PM
  #11639
I dodged the bullet for so long with the original screw and nut setup I never really considered anything else. Must be "carma" or something! I'll be stepping up for the pro diffs for sure now.
pcar951 is offline
Old 03-31-2008, 07:08 PM
  #11640
Stew Noble's Avatar
Originally Posted by yokemad
@Stew
Cheers
Yep, Elliot is an Xray driver now.
The 008 is certainly a nice car, both in quality, how it appears on the track and a few cool innovations in design, in the UK there's a pretty big Xray team, so should you ever need assiatance, it's easy to get too.
