Tamiya mini cooper
#2251
thanks for the response guys!
akuhon, have you tried placing your esc inside the chasis (if it fits)? maybe it could help a little with you weight transfer..
#2253
OK guys just added full pics and specs and drawings etc etc for the Chevron rear mount steering conversion. So anyone that wants to build one should find most of what they need at rc-mini.net now.
As for Akuhons tyre question... Well, on a personal level, I still run X patterns (non-evil ones) but most of the other guys in our group run Pit Shimizu's or sometimes Rides (S compound) On a really large track we might use Type A 60D's, but they are compromised on turn-in.
The Tech 4WD M01/02 conversion? Its one of the few things that we havent been able to get hold of. Bizkit has one though although it isnt currently assembled I believe.
#2254
On the rear servo conversion, Does the steering link plate change the length/angles of the steering rods? Did this reduce the bump steer?
#2255
It improves it slightly but not by much. You're never going to eliminate it completely on an M03, its almost impossible to do so.
However, if your handling is being compromised by bump steer then your car is probably set-up too soft anyway. The bump steer only really has an effect when the wheel moves up a good 5mm+ And a race Mini shouldnt have anywhere near that much travel.
#2256
Thanks Tony. Just curious as the pics look like the steering links were shorter.
I agree that bump steer will be a problem at 5+ mm up/down movement and too soft of a set-up.
#2257
hey racenut,
i guess it will be touring car tires for us at jp. or go with akuhon's set-up, foams, super low ride height and firm suspension.
#2258
Originally Posted by akuhon
Do you also have M01/M02 4WD conversion by Tech Racing ? I think this one is the oldest conversion for M-chassis. Now, they (Tech-Racing) did the same thing with M03 .... Post some pics if you have, here or in your web...
Cheers,
#2259
And also, I see you post HPI mini tires. It's rubber, right...
Do yuo have any experience with other rubber tires for m-chassis ? I see there are some from : RIDE, PIT-SHIMIZU ....
Please share with us..... I don;t have any experience with them 'cause I only use foam....
Actually because it's cheaper than rubber (cost of rim, insert and tires) and it fits my style....
if anyone is using a different insert setup they really have success with please pass it along! Thanks.
#2260
Thanks Tony and minimanintaiwan for the info about rubber tires.
I wil try to order some ....
SUP:
yes, I've tried to mount them on the rear at the both side (left and right) of the rear chassis, but still need some weight... Never inside the chassis...
racenut:
I never mount it on the rear... I always mount the transponder on the front part ...
Any idea of the mini-rims ? .... this one for my shelfqueen ... the Fit / Jazz
SUP:
racenut:
#2262
Mods, Hacks
Would this be the place to post about mods and hacks to the M03?
http://i16.photobucket.com/albums/b7...8/DCP03453.jpg
#2263
Besides a weight factor what are the performance differences between a manta ray ball diff and TA03 ball diff in a M03M chassis and all other things being equal?
I have a TA03 ball diff and seem to be a bit quicker on the straightaways.
#2264
The 03 diff is lighter ( and less contact surface hence less friction), so theoretically will spin up to top speed quicker on the straight.
In practice though there's no actual mathematical gearing advantage with either of them. The effective ratio is identical
#2265
stearing problem
Hi Guys.
Last week i purchased a mo3m swift and have a problem. It was built in a hurry for racing friday night.
It appears that the front right wheel is momentarialy locking up.
when i first put it on the track it ran fine for about 50m then dived hard right into the track guides, this diving to the right happens about evry 10 meters or so for the first couple of laps.
After a few laps it seems to settle down but for the first couple it is a real bugger.
I put it o the stand and everything seems quite free.
At first i thought it may have been the radio as i am only using a cheapy until i get another reciever for my KO. but i noticed that there are wear patterns on the tyres consistent with the wheel locking up.
any help would be appreciated.
Cheers
Ross
Cheers
Ross
