Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-12-2006, 06:08 PM
  #2281
stulec52's Avatar
Trader Rating: 26 (100%+)
good enough then, I'll stick with my regular packs ( 4200IB Worlds series! - might be a bit much for silver can racing, but I do like to have good cells)
stulec52 is offline
Old 11-12-2006, 06:32 PM
  #2282
tony gray's Avatar
Well in restricted motor classes like 540 Silver Can or Sport-Tuned the cells are THE most important thing of all.
Over here you either run 4200's or you're nowhere.... The newer 4200's have SO much more voltage that you have to run them.
tony gray is offline
Old 11-13-2006, 04:45 AM
  #2283
minimanintaiwan's Avatar
Originally Posted by TENCHO
check out these cool M03M aluminum parts from SQUARE....too bad they don't have actual fotos yet...
http://www.rc-square.com/parts001.htm
try Jason's store on ebay, he's got some Square parts for M03M.AlsoTechRacing and Tobee. With fotos too!!
http://stores.ebay.com/Jasons-Store_...QQftidZ2QQtZkm
minimanintaiwan is offline
Old 11-13-2006, 06:49 AM
  #2284
Customworksking's Avatar
Trader Rating: 74 (100%+)
Talking
wow killer parts wish they were TCS legal Ide buy em all for the Novak race but they use TCS rules as well
Customworksking is offline
Old 11-13-2006, 02:52 PM
  #2285
TENCHO's Avatar
Default New MINI!
a new mini will be realeased this weekend at the Tamiya Fair in japan.
It will be a M04L with a Volkswagon Beetle Body.
I can't wait to see the pics.
here's the link...it's in japanese though.
http://www.tamiya.com/japan/tamiyafair/index.htm
TENCHO is offline
Old 11-13-2006, 03:15 PM
  #2286
Default shock length
I have read that you can reduce ride height (M03M) by shortening the standard shocks by adding 5mm of fuel tube or o rings to the shock shaft.
My question is if I do this do I then have to reduce the rubber tube on top of the shock by the same amount.
Ross
oldfart is offline
Old 11-13-2006, 09:44 PM
  #2287
tony gray's Avatar
That would be like THIS then Ross?....
I cant remember exactly because we did this so long ago. But from the looks of it the rubber tube looks standard length to me. I dont have a set of those shocks any more to check unfortunately.
Easy way to check, try it standard length first, and if it doesnt fit you can always trim it..
Old 11-15-2006, 04:11 PM
  #2288
Arrow M03M
just done 1 more mini body for the novak race now i need to build the car
Attached Thumbnails Tamiya mini cooper-s4010206mini-1.jpg   Tamiya mini cooper-mini-02.jpg   Tamiya mini cooper-s4010204mini-03.jpg   Tamiya mini cooper-s4010203mini-04.jpg   Tamiya mini cooper-s4010202mini-05.jpg
Old 11-16-2006, 03:45 PM
  #2289
Talking got the car done
this is some of my best work yet
Attached Thumbnails Tamiya mini cooper-s4010202.jpg   Tamiya mini cooper-s4010208.jpg   Tamiya mini cooper-s4010207.jpg
Old 11-16-2006, 08:13 PM
  #2290
Bikerbob's Avatar
Default Whats up with that?
Ok, I go out and buy the M03M parts tree with the uprights the extention piece etc...
I go to install the uprights to night.. and my bearings from my M03 will not fit the rear hubs of the m03m... what is the deal there???
i was under the understanding that all bearings for all MO2-Mo3 Mo4 were the same?? Has something changed?
I dont have a MO3M manual.. can anyone tell me the bearing that is supposed to be in that upright??
James
Bikerbob is offline
Old 11-16-2006, 08:50 PM
  #2291
Target's Avatar
James
You can get the manual from
http://www.tamiyausa.com/pdf/manuals/58368ml.pdf
Target is offline
Old 11-16-2006, 09:16 PM
  #2292
Bikerbob's Avatar
Well there ya go..
So.. one more difference between the M03M and all older M Chassis cars.. The outdrive bearing sizes have changed.
All older cars run an 1150 .. and the new Mo3M runs a 1050
SO.. now I need 4 1050 bearings.. grrrr
James
Bikerbob is offline
Old 11-16-2006, 09:25 PM
  #2293
Arrow car
Well there ya go..
James
MY kit came with all new bearings
Old 11-16-2006, 09:30 PM
  #2294
tony gray's Avatar
Yep, the complete kit comes with bearings, but if you just buy parts trees like James did you still need to buy the extra bearings.....
Quite why they changed the bearing size on the rear uprights I dont know. The original toe-in uprights were fine as they were.
Old 11-17-2006, 12:12 AM
  #2295
akuhon's Avatar
Well there ya go..
James
I think U need 8 not 4 bearings
akuhon is offline
