1/10 R/C F1's...Pics, Discussions, Whatever... >
Like Tree2910Likes
Old 04-30-2013, 05:22 PM
  #8011
Trader Rating: 13 (100%+)
Originally Posted by JayL
How do you know you are 1 sec behind so you can open your wing?
it's 1/10 scale. It should be converted to 1/10 second behind.
So, never open the wing.
*it's free of use in qualifying though.
nicholasxuu is offline
Old 04-30-2013, 05:45 PM
  #8012
edhchoe's Avatar
Trader Rating: 41 (100%+)
A speed defendant spring loaded clutch may be a better answer to activate the spoiler lifting mechanism but that would add weight to the rotational mass somewhere.
edhchoe is offline
Old 05-01-2013, 06:26 AM
  #8013
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The DRS system is sorta funny. I see no advantage as we have way more torque and horsepower in our scale cars. Just more weight on the chassis as Ed pointed out.
liljohn1064 is offline
Old 05-01-2013, 06:29 AM
  #8014
Marty Peterson's Avatar
But it looks so cool! But the wife looked at me like I was crazy when I said I was going to buy it just to have it.
Marty Peterson is offline
Old 05-01-2013, 06:37 AM
  #8015
I would have Alonso's luck with the Bahrain GP. Poor Fernando.
Old 05-01-2013, 07:06 AM
  #8016
Not that I am a fan of F.A. I am a Ferrari fan, but I love all the cars, there's nothing better.
I feel if one car stops working none should work. same with the kers (kinetic energy recovery system) then again I would mind if they got rid of both of them.
Old 05-01-2013, 07:12 AM
  #8017
Not to change the subject but for the people out there that want to try running HPI Vintage wheels and tires I still need to know if anyone else wants to jump in on this, the more we buy the cheaper they will be. I am going to get my self a set for the VF1 Car I have!
Rear 14 to 12mm Hub Adapters for all Tamiya type rear hubs. Full details under post #8008 right here.
Old 05-01-2013, 07:14 AM
  #8018
howardcano's Avatar
Trader Rating: 37 (100%+)
RCTech user Grenade10 used a similar system on the wing of a Chapparal HO slot car way back when he was a kid. It used the motor rocking side to side in its mount for actuation; angled under deceleration, flat under acceleration. There was no performance gain, but it did psych out the other drivers, who thought it might have an effect.
howardcano is offline
Old 05-01-2013, 07:33 AM
  #8019
I'm definitely interested Marty!
Team Lotus is offline
Old 05-01-2013, 08:37 AM
  #8020
NutDriver's Avatar
Trader Rating: 30 (100%+)
Ditto for me, Marty. Any idea what the cost might be on the high end?
scott
NutDriver is offline
Old 05-01-2013, 09:13 AM
  #8021
Cadman1981's Avatar
Anyone know what happened to the d-drivesportsenglish site? it's been under construction for months...
Cadman1981 is offline
Old 05-01-2013, 09:40 AM
  #8022
Hy guys one japanese have made a fantastic really driver for the f104 , i am sorry but can not write the url , but search in you tube this
RC F1 ONBOARD CAMERA 8 LOTUS E20 on track .
prostracing is offline
Old 05-01-2013, 10:02 AM
  #8023
scott
No Scott, it will all come down to how many is made and what they will be made out of, Nylon I would guess it would be the cheapest, then plastic, last Aluminum, but I should know in the next 48 to 72 hours.
I do not think it will be all that much, the design, setup & run time is what coasts the most. no, matter what the part is made from.
@ David I knew you would be in for a set.
Old 05-01-2013, 10:26 AM
  #8024
Manny's Avatar
What are the holes on the brake disc for? Did they do that in the 60's? (Sorry, just being a smarta$$) Anyway, sign me up! You're doing the front and rear?
Manny is offline
Old 05-01-2013, 11:08 AM
  #8025
Trader Rating: 12 (100%+)
Default Nice
[QUOTE=Marty Peterson;12103163]Hi everyone, The Age Old Question? 14mm to 12mm rear hubs & F103, 04, Pro, ..... Front Knuckles & Axles for 12mm Hubs?
Look nice, Marty! I have made adapters like your first design in the past. I drilled the wheel to accept a flanged bearing to support the wheel on a wider base. Works well but then the wheels are modified.
Let's do some brainstorming on making some front adapters similar to your rears for the front. It would be great to just use the F104 type parts and the VTA wheels!!
I used the Tammy GT rear diff and rear adapters which are 12mm and it works out to 190 mm wide with the VTA wheels. This would be a simpler and likey cheaper solution.
Have you laid out the width on the front end with this type of adapter and the different width arms? I think it may require the narrow F104 arms to get downt to 190mm.
One suggestion-The disks on most of these cars were not inside the wheels as they are today. They were inboard of the wheel in the airflow. Consider moving the disk inboard for more realism!!
1/10 R/C F1's...Pics, Discussions, Whatever...-lotus-49-cosworth_9.jpg
aarcobra is offline
