Tamiya TB-03
#527
Shock upgrade
I'm considering upgrading my shocks sometime soon on my TB03. Is there any real difference between these two besides color:
http://www.tamiyausa.com/product/ite...oduct-id=42102
and
http://www3.towerhobbies.com/cgi-bin...9&I=LXVBT5&P=K
Are these the best TRF shocks out there for the TB03?
and
#529
and
and
http://www.tamiyausa.com/product/ite...oduct-id=53571
Go to tamiyausa.com and search for TB03. then select one of the race car kits and then click the hop up tab above the kit picture. There are 4 shock sets you can purchase. All are a great choice for your kit
53571's are a gun metal grey color. You also have all black, black with blue caps and the MR version which are all blue.
Jimmy W.
#530
Timmie,
It sounds like you had a blast no matter.
Yes after receiving my carbon chassis this will solve a lot of suspension tuning issues. Not that the car is bad of course but it will help to be able to dial the suspension in that much better.
The chassis is only .9g lighter but is much stiffer!
I went through my TB the other night and set it up for our next race for RCGT in a couple of weeks which will be our spec rubber tires on carpet.
I'm getting closer to this thing becoming a "TB03R" as I've installed all of the carbon/plastic, titanium screw kit, aluminum balls, aluminum battery posts, I went to the aluminum out drives (which only add 1.6g ea diff) and the carbon tub that I modified so the 5000mah LiPos will sit flat in the chassis and stay put.(removed 1.5g by doing this) all in all from kit stock I've managed to take off 114g's!!! and I have more that I want to do. (Ti outter axles, carbon battery holdown, carbon rear shock tower, carbon bumper plate, Ti hinge pins, aluminum prop and gear shafts)
Right now race ready with my Calsonic R35 body I tip the scales at 1450g!
I'm looking at being under weight to allow me to add weight were I need/want it.
Oh yes the plastic tub owns on outdoor tracks Interested on how the carbon tub performs for you on carpet. I was running hara springs this weekend, but they would be pretty close to running tam blues in the front and yellows rear. Oh and a one way diff. Did you get the chance to test some bodies out this weekend by chance? And one more thing will you be at the TCS nats at the end of this month? Would be cool to meet you
Glad your getting the weight down on your car. I got mine down to 1460, still got to loose some somehow. Is grinding the chassis for better lipo fitment legal for TCS races?
#532
These are the units I have on my TB:
Jimmy W.
Jimmy W.
#533
Awesome run Timmie! I think the main was when your car looked the best. Your 2nd qualifier was not so good when I videoed it. Did you watch the videos yet? You could see the traction rolls. But going down on spring was the way to go with soo much traction. Can't wait to see what you can do with the carbon tub chassis. That plastic one had too much flex. I think with stiff springs, it transferred too much stress on the chassis. The softer springs put stress back on the suspension and let the car roll more instead of flip. You racing this weekend? Hope they finish the new drivers stand. See ya soon!
#534
I dont suppose those vids are online are they?
#535
How are you guys adjusting ride in the front? I am running trf dampers and standard size white springs. With the collars screwed all the way up i am only able to get to 7mm ft and 6mm rear. I think the car should be 4.5-5mm . am i correct? Running on High traction surface. Should I adjust the pushrods, buy the short spring set or screw the droop screws down to get the height? which is the proper way to set RHt on this beast Thanks, fat
Also,So putting shims under the rear outter ball stud gives me more camber change adding more rear traction?
#536
#537
Nice! I'm parking my BD5 for a couple weeks until I get it rebuild with those graphite arms. In the mean time, I'm going back to my 415MRE with 416 suspension setup. I'll catch ya at the track!
#539
Oh and yes, more shims under the rear outer ball stud will give you more rear traction. A basic way of looking at it, is that whatever end of the car has camber links that are angled more DOWN in the center of the car, that end will have more traction due to more camber gain. So lets say my car's steering felt a little too aggressive, I could add shims under the inner front link, this reducing camber gain traction in the front, will take away some traction in the front of the car, taking away some steering. If lets say my car had too much rear traction, I could take away the shims on the rear uprights, or add some to the inner link....but on the TB03 that requires you to take the rear shock tower off, so I just make my changes at the upright.
#540
Location: A step closer to where I need to be a step further from where I was
Timmie gonna assume you have seen this.
Rod
Rod
