Novarossi engines thread
#2881
I wanted to thank Novarossi for the great motors. I have been running these motors now for about 1 year and they have been awesome. My sedan has never been so fast. The power on in the infield has been great. Once again my 353 has powered me to another TQ and win. This time taking the victory in the 4th round of the Florida State Series.
Thanks again Novarossi,
DJ Apolaro
DJ Apolaro
#2882
DJ,
what pipe did you used with your 353.
thanks
thanks
#2883
2630, short header with 16% #6f plug
#2884
#2886
Hope this helps,
DJ Apolaro
#2888
Review
Has any tried the B2000BF if so could you rewiew the low cost Novarossi motor? It's going in a xray 808 buggy......Also what's a good pipe for this engine.
$150
http://www.amainhobbies.com/product_...ducts_id/31073
Thanks....
$150
Thanks....
#2889
Sounds to me like you got a motor that is just broken in. Hopefully that is the case. How does the pinch feel without the plug. Does it seed at TDC nicely. Also with the plug how is the compression. If these 2 things are good than I would run the motor rich for about the first 7 tanks just to make sure of the break in and then go for the race tune. Make sure it is shimmed for the fuel %you are going to use.
hope this helps,
DJ Apolaro
hope this helps,
DJ Apolaro
i have just seen your message weirdly
the piston locks at the TDC with the glowplug. i can hear some little"blug blugs" like coming from tiny air bubbles. it is tigther than my 2 race old JLR evo3.
im going to use it with %16 fuel and im pretty sure the man who i bought the engine from used with %16 fuel
should i breakin the engine assuming that it is completely new?i use WOT method for breaking in engines
thanks for the reply
#2890
hi apolaro,
Good luck,
DJ Apolaro
#2891
thanks, i will
should be used with 2630 or 2601, right?
#2892
