T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 10-05-2010, 04:39 AM
  #5851
stiltskin's Avatar
Trader Rating: 103 (100%+)
Originally Posted by Professor
initially had 46mm shafts in & yes the blade was sitting on the screw/nut but then changed to 44.5 mm & problem still ocured,will try the heating & cooling method & see if that fixes the issue
thanks for the help
Are you running a narrow rear end? How many shims are you using between the arm and bulkhead?
stiltskin is offline
Old 10-05-2010, 05:06 AM
  #5852
Professor's Avatar
Trader Rating: 12 (100%+)
hi tony
its built to kit settings,the only difference between the new car (the one thats throwing c clips) & my older car (which hasnt lost any c clips) is the new car has the lipo chassis & belts have been flipped over from standard
appreciate any input
graham
Professor is offline
Old 10-05-2010, 09:35 AM
  #5853
cheehtae's Avatar
Trader Rating: 15 (100%+)
subscribing.
cheehtae is offline
Old 10-05-2010, 03:57 PM
  #5854
Trader Rating: 11 (100%+)
for those of you whose running the gear diff, can someone tell me how thick is the included shim?
Thanks.
cvccsi is offline
Old 10-05-2010, 04:47 PM
  #5855
stiltskin's Avatar
Thanks.
.10 mm in mine. I believe there were two on each side.
Old 10-05-2010, 04:48 PM
  #5856
cheehtae's Avatar
cheehtae is offline
Old 10-05-2010, 04:52 PM
  #5857
Thanks. There is also the red spacers, what is the thickness for that?
cvccsi is offline
Old 10-06-2010, 08:32 AM
  #5858
cheehtae's Avatar
is there an easy way to change the spur? what is the first step after removing those small screws. I can't get the bearing, red shaft off the pulley. It's stuck.
cheehtae is offline
Old 10-06-2010, 10:39 AM
  #5859
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
You may have over torque those two screws ,it will mushroom the red shaft end cause the bearing to stuck..
Hold the spur gear and force the shaft out , then deburr or handfiles the red shaft ends brfore reassy.
OVA is offline
Old 10-06-2010, 11:23 AM
  #5860
E.J. Evans's Avatar
We came out with an optional steel shaft which now comes standard with the kit.
TC-PDT005BK Centre Pulley Shaft (Black)
The problem with the aluminum one is that it mushrooms when the screws are tightened and the bearings won't come out.
Shoot us en a email [email protected] and we'll work something out.
Thanks,
EJ
E.J. Evans is offline
Old 10-06-2010, 11:33 AM
  #5861
E.J. Evans's Avatar
hi tony
graham
Hi Graham,
Wornout outdrives can cause the C blades to break. Also if the flat surface has any deformation, knicks, or sharp edges that can cause it too. Try filing down the flat to make sure it's smooth.
If it continues to do break blades send me an email [email protected] and I'll send you some replacements to start "fresh"
Old 10-06-2010, 11:37 AM
  #5862
vabroom's Avatar
Outstanding service and support as always.
vabroom is offline
Old 10-06-2010, 10:20 PM
  #5863
Professor's Avatar
Originally Posted by E.J. Evans
Hi Graham,
thanks e.j.
i"ll give the outdrives a clean up,give the car a run & let u know how it goes
thanks for the help & support even from the other side of the world
graham
Old 10-08-2010, 04:52 AM
  #5864
I just picked up this kit. It will be hear today. Does the kit come with a basis rubber tire/ carpet setup? I will need to adjust to my driving and track but a ballpark setup to get started will save me some time.
We mostly run 17.5/ full software class at my track.
DJG24 is offline
Old 10-08-2010, 05:00 AM
  #5865
Pro10noob's Avatar
Trader Rating: 13 (100%+)
The manual has 2 basic setups in there.
1 for foam and 1 for rubber.
I don't know what kit you got?
The rubber or the foam?
If you have the rubber kit there will be only the small "wings"in the kit for the rubber setup.
I just bought me one also and put the basic setup on the car and it works ok.
Just need to adapt it to my own driving style and fine tune it.
regards Roy
Pro10noob is offline
