Tamiya TRF418
#946
What diff seals are guys running to keep the diff from leaking. I heard someone locally tell me something about a yokomo seal. Is that correct? Can someone tells the right part number?
I've searched the thread and can't seem to find the info I'm looking for.
Reeeeevised. Thanks
Reeeeevised. Thanks
#947
I've already tried the kyosho seals. And while they seal fine. They are to tight to the Outdrives. I know some of you will disagree. Try taking your diff apart. And try to lightly spin the outdrive and diff half. It will be slightly tight. So if you are trying to run 500-1000 weight oil in the diff. The seals make it feel like 2-3k is in it without any oil. Just because the seals are that tight on the Outdrives. Don't believe me? Compare a diff half with a kyosho seals. And a stock black seal. And see the difference.
A couple of us locally all switched to the kyosho seals. And couldn't figure out why our diffs felt so tight when we were all running the same oils we were before.
#949
Reeeeevised. Thanks
Reeeeevised. Thanks
http://www.thercracer.com/2013/07/ho...gear-diff.html
We have used the Kyosho o rings and the Tamiya ones (the red ones) and both seem fine.
#950
^ I followed your guide pretty much as well with the use of VG diff grease in lieu of green slime and the tamiya shims (0.3mm)
I also sanded the gears slightly - to 3.60mm and 4.55mm exactly.
The VG grease is very smooth with a quite distinct smell to it actually!
No leaks so far!
Word word of caution is the VG grease needs to be used with mineral oil only though.
No leaks so far!
#951
Here is a guide. Myself and the other Tamiya guys build our diffs like this and have no leaks. (Metal gears are essential for offroad 4wd)
#954
I don't usually spam my blog but my method is here - http://fiveeight0sixsix.wordpress.co...iff-a-la-dave/
#955
Solution is to use thinner shims. Kit 0.3mm are too fat for the red rings, use some 0.1mm ones. Adjust until you are happy. Don't file anything down.
In my current diff, I'm using black orings with (1) .3 on one side and (2) .1 shims on the other side because a .3 was too tight.
PS: The credit goes to Nick for discovering this. I blindly built mine with the Tamiya red orings and just accepted the tightness. I also started with 2k oil so it wasn't as bad but now that I'm running 500, the outdrives need to freer, in my opinion.
#956
That's very low, never heard of anyone using that low cst in a diff before in any make of car (but it maybe needed where you're racing, lol). Is this for carpet or asphalt, what motor class?
If I may, I would suggest you stick with the orange o ring (Kyosho or new Tamiya o-rings, no more leaks) and try getting more off-power steering some other way. Have you thought about adding some anti-dive, reducing your camber, or shorten your rear wheel base...
#957
Not exactly... while the .3 shims make it extra tight with the pin in, the real issue is the inner diameter of the red oring. Try it for yourself, assemble a diff half with a red oring and an outdrive. Hold the outdrive in one hand then try to spin the diff half. Notice the friction. Now take a kit (black) oring and do the same thing. You will notice that the black oring is much freer. Orings were lubed with green slime and shock/diff oil for testing.
- Jose
#958
I have no problems with my diff. I have the steel gears and the oil from Kyosho (1000). Did the diff built exactly according to the instructions together and not a drop is lost.
#959
Being the grumpy old man I am, I thought Tamiya diffs were too last year (and quite agricultural too), so I machined 1mm off shoulders on either side of an Xray diff and replaced the Tamiya item. This requires Xray belts and driveshafts, but saves 15grams for each end of the car.
Nice.
Then I had another idea and changed the Xray diffs to the Corally SGX diffs (same weight as Xray) I had lying around which means I could use Tamiya driveshafts on the rear (with 46 or 48 mm dogbones) and the 46mm on the front (I changed those too in fact to Yokomo 40.6 items simply because they're nicer). Belts remain the Xray items 305431 front (507mm/169 teeth) and 305444 (183mm/61 teeth) rear.
Didn't manage to figure out how to use silicone oil in these without it leaking all over the place (Corally use a "syrup" so dense it would take the rest of eternity to fill the diffs) so I used silicone grease, nice and sticky.
There you have it.
Internal ratio changes of course, so you can use smaller pinions to boot. Corally actually make a 37 tooth pulley for the SGX diff just to piss off Tamiya, but I didn't see the point.
Next job is to change the servo holder which I find too chunky to an Xray carbon plate (T4) which happens to have the holes exactly at the correct distance to fit in the Tamiya chassis and some Corally posts (F1) and inner TA05 servo holder. The Corally posts will need some machining again, but boy do they look sleek.
Nice.
There you have it.
#960
Nice.
There you have it.
Nice.
There you have it.
