Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 05-26-2011, 03:06 PM
  #5266
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by InspGadgt
Other things to check for is your left to right balance and a rear axle that is too tight. If one side of the car is heavier than the other it will cause the car to act tweaked. And if your rear axle is too tight then you will have more drag on one side of the diff than the other which will also cause the car to feel tweaked. You need to have a slight bit of play in the rear axle to prevent it from binding.
Very true! I am realizing that the axle bearings are very fragile. Twice in the past month I have found a 'chattering bearing' on the axle. This was causing the axle to not be as free so it was making the diff uneven left to right causing erratic cornering until the bearing was replaced.
....you reading this Cuda?lol
MikeR is offline
Old 05-26-2011, 03:10 PM
  #5267
eevul's Avatar
Originally Posted by robk
When was the last time you changed your front springs? They will collapse over time, especially the left one on a counter clockwise track and vice versa. Also, are you gluing the side walls on the front tires? That will calm the car down. Are the tire sizes even left to right? How long is the sauce on for? At least 15 minutes?
What are you setting the ride height at? Sometimes a slightly higher front height can help if your car is not getting traction. Another part that might help you is the 3.5mm offset steering arms. They will help the car track straighter and take away a bit of steering.
Also, make sure your body is not fouling the wires or rear pod in any way. If you have to raise it up, do it.
Here is a setup for a VERY high bite track with A foams:
https://docs.google.com/viewer?a=v&p...MmFkMjU2&hl=en
The front springs were changed for our last TCS race here. If I remember correctly, my ride height is 5mm front and 3 to 3.5mm rear. I have also added some weight to the rear of the car and it did seem to help some. I had also tried letting the sauce sit for 10 to 15 minutes. I don't have the 3.5mm offset and I have been trying to get some of those but hard to find them up here. In my opinion, the car has way too much steering so the offset steering arms might help. I took the entire rear assembly apart before our last TCS race and made sure that everything was correct (not binding, stripped, broken, or whatever). The car still had the same issue. I am running a Futaba 9652 servo and I have turned down the EPA and EXP.
I will check the body height for clearance and then mess around with the support trays and see if there is an issue there. Heck, I might just strip the entire car and rebuild it again just to see if I missed something. Thanks for the suggestions so far.
eevul is offline
Old 05-26-2011, 03:33 PM
  #5268
Hi,
Some put 70grms weight at the rear diffuser.
rccartips is online now
Old 05-26-2011, 08:20 PM
  #5269
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Is mounting the servo with the output shaft up (a la robk) considered TCS legal?
-rocky b
flatspunout is offline
Old 05-26-2011, 08:36 PM
  #5270
robk's Avatar
Trader Rating: 22 (100%+)
It was at the last TCS race I ran
robk is offline
Old 05-26-2011, 08:45 PM
  #5271
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Hey man, you pickin on me?
I too go thru bearings like dollar bills at the strip club.
Not sure if that would explain why the car is a bullet for about 4 or 5 minutes at the most.
Happens all the time for me with foams on asphalt.
Gotta figure how to get it better for when the "dope" is used up from the tires.
F N CUDA is offline
Old 05-26-2011, 10:53 PM
  #5272
gsxr0311's Avatar
Trader Rating: 19 (100%+)
anybody have a f104w?
gsxr0311 is offline
Old 05-27-2011, 01:09 AM
  #5273
I have transformed my F104 pro to a F104w.
I think that the only differences between two models (F104 vs F104w) is that the F104w uses the F103 tires and F103 front arms. Rest of the cars are similar.
In my opinion, if there are no rules regarding the width of the models, I would prefer the F104w, my experience is that is more stable entering and exiting curves.
Regards
victor_assob4 is offline
Old 05-27-2011, 07:40 AM
  #5274
eevul's Avatar
Nice. I'll have to replace mine on my car for sure. During the last rebuild, I noticed that the rear axle bearings were 'notchy' but I didn't have any replacements. This could be part of my problem.
Does anyone know the part number for these bearings?
eevul is offline
Old 05-27-2011, 08:20 AM
  #5275
gsxr0311's Avatar
Regards
thanks for the response. do you know if the arms that come with the f104w have ride height adjustment? i also have 103 arms on a 104, but i cant adjust the front height. i think you can adjust the new 104w arms.
gsxr0311 is offline
Old 05-27-2011, 08:21 AM
  #5276
macavant's Avatar
Trader Rating: 65 (100%+)
Thumbs up
macavant is offline
Old 05-27-2011, 10:04 AM
  #5277
Foam or rubber tires?
InspGadgt is offline
Old 05-27-2011, 10:05 AM
  #5278
No...they are the same as the F103 arms and don't have any ride height spacers. At least on my Lotus F104W.
Old 05-27-2011, 10:30 AM
  #5279
eevul's Avatar
Foam as mentioned in my post.
Also, the part number for the rear axle bearings are Tamiya #53270. It's amazing the things I'll find when I use Google . These bearings are 6x10x3 if I'm not mistaken.
eevul is offline
Old 05-27-2011, 10:42 AM
  #5280
F N CUDA's Avatar
You can make adjustments by shaving down the tops and or bottoms of the spindles then replace the removed material with shims on the opposite side to raise or lower the ride height.
This has worked for me and allowed me to run more ride height for smaller diameter tires (foams) and lower ride heights when running taller rubber tires.
F N CUDA is offline
