Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 02-19-2015, 06:51 PM
  #8086
Magnet Top's Avatar
Earl, try moving the steering rack back. It's quick and easy too. It could make the car turn in a little faster but at the same time, depending on the toe, it can reduce the late oversteer. Also if traction is low / medium try running thicker gear diff oil... like 3000 to 5000 rear diff so the rear won't over rotate. That with less static camber as I mentioned before ( 1 degree in front and 1.5 in rear ) should help.
Also I agree with Hanulec too, remove some shims under the rear toe link to cause a little bit of toe-in during compression.
[edit] But I just remembered you were avoiding bump toe due to a bumpy track.
Jake D.
Magnet Top is offline
Old 02-20-2015, 03:58 AM
  #8087
BardSmith's Avatar
Trader Rating: 64 (98%+)
Does anyone have 2 pairs of AR-19s they want to sell? pm me pls
Attached Thumbnails Awesomatix EP Touring Car (A700 Shaft Drive)-a700-am19-270x270.jpg
BardSmith is offline
Old 02-21-2015, 10:54 AM
  #8088
b20btec's Avatar
Trader Rating: 11 (100%+)
Is the carbon upper deck applicable for the new evo 2? What track condition would it be useful for?
b20btec is offline
Old 02-21-2015, 05:36 PM
  #8089
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Yes, same topdeck as evo 1. Its good for hi grip carpet.
geeunit1014 is offline
Old 02-22-2015, 07:02 AM
  #8090
b20btec's Avatar
Thank you. To confirm the part is A700-C21-2?
b20btec is offline
Old 02-22-2015, 09:11 AM
  #8091
Yes, C21-2.
http://shop.awesomatix.com/index.php?productID=1040
Oleg Babich is offline
Old 02-22-2015, 03:30 PM
  #8092
b20btec's Avatar
Originally Posted by Oleg Babich
Thank you, I'll have my local track order it!
b20btec is offline
Old 02-22-2015, 05:56 PM
  #8093
Trader Rating: 12 (100%+)
Default Awesome Weekend!
I just got home fron the VTA Carpet Nats in Fort Wayne. I put my Awesomatix cars in the A main in USGT and VTA. Probably had the best weekend of racing that I have had in a long time. Want to thank Mike and everyone else on this thread for the setup help that you have given me that allowed me to BE COMPETETIVE at a event like this. I really enjoyed the cars!
TWILL is offline
Old 02-23-2015, 06:34 AM
  #8094
Any chance I could see your VTA setup sheet?
trackout is offline
Old 02-23-2015, 08:24 AM
  #8095
Is there a PDF manual for the EVO II somewhere?
Ted Su(TW) is offline
Old 02-23-2015, 08:53 AM
  #8096
Have a question regarding the steering rack. I see most use the inner steering link hole. What would be the handling characteristics if I tried the outer holes?
malkiy is offline
Old 02-23-2015, 10:28 AM
  #8097
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by malkiy
Have a question regarding the steering rack. I see most use the inner steering link hole. What would be the handling characteristics be if I tried the outer holes?
I thought of it the same thing
maybe just a clearance over the ball cup from lock to lock steering or make a shorter steering rod.
OVA is offline
Old 02-24-2015, 02:42 AM
  #8098
BardSmith's Avatar
Check out this blog to help you in your build... Link
Old 02-24-2015, 10:00 AM
  #8099
Default You have PM
I sent over the setup I used and the changes I made.
TWILL is offline
Old 02-24-2015, 11:58 AM
  #8100
WesRaven's Avatar
Thumbs up First Awesomatix car
Hey guys, mainly just wanted to introduce myself, and thank everyone that has contributed to such a great thread. I just finished reading the whole thing, trying to fill my time while I wait for my new A700L2 to get shipped, and there's definitely a ton of great info here.
I'm getting back into the hobby after a 10+ year break (brushed motors, FM radios, and NICADs were all the rage when I last ran). I have only driven Associated cars in all my years of racing (from the introduction of the original RC10 up to the TC3 when I quit, and pretty much everything in between). After reading this thread and the posted manual for the car I can see this is a very different beast from the Associated cars I'm used to. If anyone has any tips or advice they would like to give an old-timer (stuff they wish they knew before attempting their first Awesomatix build) I would love to hear anything you wish to share.
Anyway, can't wait for this masterpiece of a touring car to show up, and start getting back into the fun with you all
-Wes
WesRaven is offline
