Schumacher Mi4
#2657
sway bars and out drives
I had the same problem with the sway bars and the out drives so I rebent the bars to miss the out drives. You do how ever need to make sure that all the bends you make are the same for both sides and that the end result is that the bars are flat
#2658
I haven't had any noticeable problems with the outdrives vs. swaybars in the front. I put the o-ring into the insert, then carefully put both over the outdrive. When it pops on, check inside to make sure the o-ring is seated before sliding on all the way. When I put the sliders on this way, I had absolutely no problems with them coming loose in 3 rounds of racing and a couple test runs.
-Mike
-Mike
#2659
dont have the car in front of me right now, does anybody know if the 4mm arm reamer is the correct size for the mi4cx?
#2660
#2665
My 2c...
#2666
I have recently installed the twin point and find it a lot better. Steering is faster and more direct. I would also describe it as more linier throughout its full lock. This seems to give it the edge on consistency when pushing hard for me where the original system could make the car feel raggedy when pushing.
Admittedly the first few runs the car felt a bit edged with the twin point but you soon get used to that and now can't see myself going back to the original.
#2667
Do you think the reason it feels less raggedy could be a reduction in slop?
-Mike
#2668
Mike, are you referring to the out of the ball severe ballcup bind on the ball when brand new out of the box?---FYI i was able to loosen up my ballcups by snapping the ballcup on and off the ball it is going on -about 6-8 times each cup did the trick-every ball cup, when new, was binding--unless the ballcup was damaged due to over tightening of the rod-those were replaced
the needle nose works great-but after the initial tightness is removed--sanp on/off a few times, needle nose squeezes, then a few more snap on/off will get them freed up.
-if the ballcups bind badly-like mine did on the frnt end will steer slow, losing steering
#2669
To me it seems like the original steering has a very negative expo curve to it now. My mate has my setup on his car and the only difference is the steering, so easy to do a back to back comparison. This is also why i think the twin point has a better feel because when pushing and chucking the steering lock to lock it stays consistent and doesn't get progressive more aggressive like a lot of negative expo would.
physically looking at the two you can see why this is. The original system, no matter what initial akerman you're running, gains akerman throughout its full movement, especially after the first 50% of travel. Probably explains why there is a lot more speed scrub with it too. The new system starts of with about the same amount of akerman, when using the 2nd hole compared to 3mm of spacers on the original, but stop or slows its gain after the first , say 20% of travel.
