Schumacher Mi4
#2806
hey Rich, I was using xray cst 650 shock oil in mine at Reedy, on a low traction track it will be loose, but high bite it is ok, and when you get used to it, steal Jeffs gear diff, put 50,000 in it, and put it in the front of your car thats for low traction, I haven't done high traction yet, but I'm thinking at 100k or more that. I should have ran that at Reedy, IT IS FREAKING AWESOME.
I tried it last night on a low bite track,(speedworld) it was a bit loose when we started,,,,after the sun went down and the bite came up under the lights, the car worked very well. i am putting a VTA car together, (MI-4LP) i think I will try gear diffs front and rear and see how it goes!
Rich
#2807
Ritchie,
when I first put the gear diff together, it leaked....i tried your suggestion, and sealed it with the silicone gasket sealer,,,works great, doesnt leak anymore and is as smooth as melted butter.....
#2808
#2809
Hello Mike,
When I tested the MI4LP universals with the Schui oil gear diff, I tried with and without the black slider. After a quick appraisal I decided it was easier to just build the oil gear diff and purchase the MI4Cx universals.
So my MI4LP runs the Cx rear universals and Schui oil gear diff with the black sliders. This works and I have stronger rear uni's.
However from what I am reading here, I should build my Cx as it will be faster with higher corner speeds. I have just been lazy as my MI4LP has been working well.
I will look into the option of using the standard universals just in case I damage what I have.
Thank you,
Calvin.
Thank you,
Calvin.
#2812
Hello Mike,
Thank you,
Calvin.
Thank you,
Calvin.
you may want to replace the front spool, and axles/universals and try that. also, the chassis is narrower, that may have a rolein things as well.
rich
#2813
where are you guys at on the gear diff shimming?
i use schumacher 70w. and run mod, 6.5 fully tekin boosted/turbo'd
started with .2 on the inside, and .1 on the outside--it eventually stripped after about 4 full day of racing.....now i have all 4 shims (.2 and .1 on each end) on the inside, none on the outside.
anybody else going to Jackson for the onroad nats?
#2814
Hello all again,
I asked my LHS to order in some long front arms for my Mi4LP and they came back to me saying they cannot find a part no# for long arms. I've look as well and no luck. Are long arms a Mi3 part? Can anyone help me with part no#?
Thanks in advance,
Michael.
Thanks in advance,
Michael.
#2815
Hello all again,
Thanks in advance,
Michael.
Thanks in advance,
Michael.
I don't think Schui stocks all the long ones anymore, though.
If you go to www.racing-cars.com, click Vintage Car Parts, click Mi-4, and then Suspension.
-Mike
#2816
I checked the shuie site, Mi3, Mi3.5, and all the Mi4s nothing listed,
checked stormers and Amain, nothing listed, its as fit they quit making the long front arm.
You could try calling shuie direct.
I have a few left but apparently I need to keep those.
#2817
Looks like you're correct and they don't have the long fronts any more. If they don't have them, then I think your only chance is shops that still have old stock, as it is VERY unlikely (read nil chance!) that they will make them again.
I'll try and dig out the part number, as I do have some arms somewhere NIP.
Note - if you can find Mi2 EC fronts, they are the same length, and just a little less beefy.
#2818
#2819
Correct - but that can be resolved with a 2.5mm drill
