Durango DEX210 Thread
#7261
Really sitting on the fence trying to decide whether or not to buy this car. I tried the 22 but never quite got it dialed to my liking. The B4.1 was pretty good out of the box, and really good with some minor mods.
I really like the quality of Durango, and even though my local shops do not stock parts, I can order them online in bulk. Recently I have found most of the local shops carry less and less of the most used parts for the B4 and 22 anyway.
So before I pull the trigger, I read several thousand pages on this thread, and based on your suggestions, I will only need a few minor parts to make the car bullet proof.
What are the most common parts to break and what should I stock up on?
Who's set up should I start out with as a baseline for a medium bite, outdoor dirt and clay track? What about indoor clay?
I have a nice low to med traction outdoor setup listed here. I really like the benefits of RM4 outdoors where grip low to med.
http://www.petitrc.com/setup/durango...603/index.html
There are many other setups you can choose from for specific conditions as well here. http://www.petitrc.com/setup/durango...ngoDEX210.html
#7262
dex 210 part Numbers
Guys,
need your help, can someone direct me to the full DEX 210 Gear diff parts lists Link/site, Im trying to get all these parts from Amain, dont ask why please... and please dont tell me just get the whole set from Tower, reason why is shipping is much cheaper at Amain than in tower... thats the reason.. hahahah...
Im missing this two parts, Highlighted below.
can some one give the link/ part numbers so that i could proceed to order it at amain.
note. E clips is already taken care off.
is the shim on the top most part this one , for the oring washer cover?
http://www.amainhobbies.com/product_...mm-Shim-Set-10
and the lower shims ( gear shims) , is it this one?
and the screws , is it this one?
http://www.amainhobbies.com/product_...x-Screw-Set-10
thanks again guys..
thanks again guys..
#7263
Guys,
thanks again guys..
thanks again guys..
#7265
The buggy is real durable. I def would get the carbon/alum steering plate. Just the std...towers, arms, etc. I have only broke a rear tower since the car first came out. I have a lot of nip that never get touched. Lol.
#7268
#7269
anyone try out the revolution designs bass front suspension block yet or how about the exotech rear hubs , the ball stud moved to the next hole over on a really light hit so i was thinking aluminum would be good , and the suspension block is just weight to the front for my aggressive bad driver style and it looks easier to clean than plastic
#7273
diff
I wanted to ask anyone here that has tried the sc10 gear diff in the car for some help. I would be interested to know if you did anything other than just shim it(which is all that I have read)? I am trying to fit a B4.1 diff in my buggy and it seems that the gear is a little smaller in diameter, so assuming the sc10 diff was the same size I was wondering how you dealt with that?
And to answer the question that I know is coming, I am doing it because the outdrives on this car suck! I know some of you don't have problems, but I also know a lot of people that do, and I unfortunately fall into the latter, so I want a solution.
Thanks in advance!
Thanks in advance!
#7274
Thanks in advance!
Thanks in advance!
Hope this helps.
#7275
Thank you all for the info and help regarding the set-ups and lipo choices. It's almost ready to run! I will let you know how it goes.
