Futaba 3GR steering trim changes when adjusting dual rate
I bought a used 3GR to see if I like using sticks again after using a wheel for the last 30 years and am happy enough with it but there seems to be a problem in that when the steering rate is increased the centering trim changes also.
Has anyone else seen this problem, I have seen some radios have an electronic calibration to compensate for wear in the pots.
Rob
Rob
Rob
Rob
Hope this helps,
Mark
I had the same isue with the FF3, it has to do that the trim and subtrim is far from zero.
Thanks for the replies, will test with everything centered and see what happens.
Old thread but wondering if anyone still reading it. I had exactly the same issues which dogged my driving whenever I used this radio, because I never noticed. I got mine in 2006 or 7, and gave up racing because my car would always wander....I found the actual issue this year after converting to steerwheel, and using the same reciever with both radios. In short, the potentiometer is glued in the wrong place in the transmitter. Open it up, carefully, cut away the glue that hold the pot in place, then you can centre by raising and lowering dual rate until it doesn't move. Then replace glue! I used shoe goo,seems great. Something Futaba should have done properly while manufacturing the unit. It did make me walk from RC for several years and was a headache from day 1 with the radio. If I changed dual rate, my car wouldn't centre, I was chasing servo, reciever, chassis tweak, and it defeated me!! Chased futaba and they have ignored my emails. Love futaba stuff but this will probably make me look elsewhere.
