Go Back   R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
Like Tree109Likes
Old 03-02-2011, 09:26 PM   #1921
snoopyrc's Avatar
Originally Posted by hotrodchevy14 View Post
I know that if you use faskolor flourescents, do not back them with the canned white overcoat..it will crack. not sure about the rest.
I have never had that happen. Maybe one of the pro level painters will chime in on this. How bout it. Doug, Dodgeboy, Andy H, Charlie B?
Edit: I have never use the Fasflourescents. But I have never had that problem with the regular Faskolor.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 03-03-2011, 06:07 AM   #1922
Buckaroo's Avatar
Usually that's caused by the base coat, in this case water based, not being fully dried. The water will eventually escape, and cause the over coat, in this case solvent based, to crack. Since the flourescent colors tend to be very light, and take several coats to get even coverage with enough depth of color, it only makes it worse.
Also, since the rattle bombs tend to spray rather thick coats, you run the risk of also trapping the propellant in the thick layer of paint, which, along with thick coats, can cause cracking.
I've been painting slot and RC car bodies since the mid 90s, never had a cracking issue related to paint that I didn't cause.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 03-03-2011, 12:53 PM   #1923
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
The white Pactra fluorescent white back-coat WILL shatter and crack if you use it behind Parma Fasfluorescent. It's the ONLY cracked paint I have had in 27 years of painting since I did my first body with Testors model enamels in 1984.
There really isn't any reason not to use Faskolor white behind Faskolor fluorescent paints.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 03-03-2011, 01:25 PM   #1924
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I personally like to use Pactra white behind all Faskolor/createx colors. For 1 I think it coats better and 2 it easy. The Pacta spray fluorescent white is junk...stay away from it.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 03-03-2011, 04:34 PM   #1925
IndyHobbies.com's Avatar
I bought one of the new Z28 Camaro bodies. Can decide whether to try to match the orange they had that year, or just go black. This photo makes me want to go black too!
If I go orange, anyone been able to get a decent Faskolor orange? The standard one is blah. Maybe hit it with a little yellow and neon orange to brighten it?
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-69camaroblack.jpg   U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!]-69-z28-01.jpg
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 03-03-2011, 05:56 PM   #1926
snoopyrc's Avatar
I am feeling that black Camaro. Go have a look at Testors Custom Laquer System Grabber Orange. You can use the Testors CLS paints but dont use The Testors Enamel. Anyway look at the Grabber orange and I think there are at least two other oranges that you might like.
Edit: Link http://www.testors.com/category/1369..._Lacquer_Paint
Old 03-04-2011, 06:16 AM   #1927
Buckaroo's Avatar
The Testors Laquer colors are nice, but make sure that you use a green scrubbing pad to scuff the lexan and clean the body well before using, or it will flake. It sprays nicely, and lays out very even, and doesn't take much to cover and coat completely, but it's not as flexible as some of the other paints on the market.
Tom Keith
Old 03-04-2011, 07:03 AM   #1928
snoopyrc's Avatar
I never scuff and have never had a problem, but I do make darn sure that all of the mold release is washed off before I spray. I could have been doing it wrong the whole time and just been lucky, but thats my experience.
Old 03-04-2011, 07:44 PM   #1929
BadSign's Avatar
Trader Rating: 15 (100%+)
I had a very similar color on my last Camaro- I started with 1 coat of Createx Flourescent Orange, then backed by 2-3 coats of Deep Red, Finished with White. It ended up a nice reddish-orange tone.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 03-04-2011, 08:43 PM   #1930
Try mixing the Faskolor orange with the Faskolor candy orange. A little Florescent orange may also help.
I love the Parma paint. It is so easy to mix custom colors.
mooby64 is offline   Reply With Quote
Old 03-05-2011, 03:03 AM   #1931
I think it's time to ditch the rattle cans and get an airbrush. I have two compressors, one big and the other small. Can I use one of these with a special regulator, or do I have to buy the air brush compressor? Also, please recommend an airbrush.
woodys3b is offline   Reply With Quote
Old 03-05-2011, 07:54 AM   #1932
hotrodchevy14's Avatar
Trader Rating: 106 (100%+)
Get a regulator and a moisture trap. For airbrush I like the paasche type H .You can also get a dual action airbrush from harbor freight for around $20 if your on a budget.
hotrodchevy14 is offline   Reply With Quote
Old 03-05-2011, 08:44 AM   #1933
I agree. I have a craftsman pancake type compressor and I shoot in the garage with a big drop cloth. But, you MUST have a moisture trap. Makes a big difference. I've got a dual action Paashe. Cleans pretty easy. And an old hairdryer will speed you up if you use Faskolor.
USVTA #144
Old 03-05-2011, 08:46 AM   #1934
It looks great. Where do you buy Createx?
USVTA #144
Old 03-05-2011, 09:52 AM   #1935
BadSign's Avatar
I use an Iwata HP-C and love it. I tried the bottom feeder types, but there's more parts to clean. It was a real hassle
The regular airbrush paints can be found at a lot of Craft / Art Stores: United Art Education, Hobby Lobby, etc. They are pretty much the standard. And cheaper than the Parma stuff, which is just re-badged.
Vintage R/C Discussion/Pics/Selling/Wanted rcaddict Singapore R/C Racers 7291 01-09-2017 09:36 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 07:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 03:00 PM
Pics of Tony Neisinger's vintage RC12L paint jobs drbelleville Painting, Designs, Graphics and Photography 8 07-12-2008 03:09 AM
