Old 08-04-2009, 01:32 PM   #2296
Green Machine's Avatar
Trader Rating: 14 (100%+)
Has anybody noticed on the new RBM3 that after minimal use it feels like the motor has no pinch??? Unlike my RBR3 still has heaps of pinch.
RETIRED
Green Machine is offline   Reply With Quote
Old 08-04-2009, 06:11 PM   #2297
KyoshokiddT.D's Avatar
? fuel
KyoshokiddT.D is offline   Reply With Quote
Old 08-04-2009, 06:15 PM   #2298
Originally Posted by KyoshokiddT.D View Post
? fuel
tommys rbm3 broke in and ran flawlesley at the glc on byrons fuel
Old 08-05-2009, 01:07 PM   #2299
KWT-NITRO's Avatar
Hi Uriah,
Its Ali from Kuwait again
just wanted to say Hi and let you know that i just got back from the FEMCA 1/8 buggy race that was held in Kuala Lumpur few days ago,
bad luck strucked me during the whole race so i wasn't happy about it, on the other hand, i ran my SIIM engine the one you modified and sent me few monthes ago.
and let me tell you man, its insanely powerfull, after one of my best 10 minutes heat (and the only lucky one), guess who dropped by my table?!! Atsushi Hara he came by and was like '' you know whats your problem?'' so i told him what, he said " you have too much power , he said, you are doing wheelies all over the track '' he also said that its the most powerfull engine he's seen in the championship, he asked about it, so i told him its a sirio base engine tuned by a spanish company and modified by Murnan Modified, he was quiet impressed and i was really happy about it. thanks Uriah for your great job on my engine
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 08-05-2009, 02:52 PM   #2300
? fuel
Meccamo , Its still fast dont get me wrong but the piston doesnt seem tight in the sleeve , whereas my 1 1/2 year old R3 MM is still tight
RETIRED
Old 08-06-2009, 04:22 AM   #2301
Big Jeff BBQ's Avatar
Default Great Lakes Challenge !
I want to say Thank you to Uriah and Murnan Modified Motors for the
help with the motor during the Great Lakes Challenge it was more than
i can drive (Safely) !
The M353 was AWSOME !
Thanks again
Jeff Epperson
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 08-06-2009, 05:26 AM   #2302
Grinder's Avatar
They have minimal pinch after fully run in. That makes the engine faster. There is just enough to seal when hot. The fit will begin to get tighter the more you run the engine. Mine has 6 gallons, and keeps getting faster.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 08-06-2009, 05:31 AM   #2303
musti72's Avatar
Are you serious about that?? You mean with same piston-sleeve, you run M3 for about 24lts of fuel and you say its getting faster??
So why most big teamdrivers run 2 engines for an event?
I am confused.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 08-06-2009, 05:31 AM   #2304
Grinder's Avatar
Originally Posted by KWT-NITRO View Post
Hi Uriah,
cheers
Ali
You are very welcome Ali. Thanks for the update.
Old 08-06-2009, 05:34 AM   #2305
Grinder's Avatar
Here is a small race report on the 2009 Great Lakes Challenge.
http://www.murnanmodified.com/newsde...newsdesk_id=98
Old 08-06-2009, 01:22 PM   #2306
KWT-NITRO's Avatar
hey great results Uriah, and welcome to the XRAY world you will have to change your signature coz it still says RRR :P
how would you compare the RBM3 to the M353R?? overall power band and run time?? which do you think is better and why ??
cheers
Ali
Old 08-13-2009, 04:18 PM   #2307
KWT-NITRO's Avatar
PM sent
Old 08-14-2009, 03:12 AM   #2308
Grinder's Avatar
cheers
Ali
I like the RBM3 better due to the increased power, increased runtime, increased crankpin, and rod durability.
Old 08-14-2009, 03:13 AM   #2309
Grinder's Avatar
PM sent
Old 08-14-2009, 03:30 AM   #2310
Grinder's Avatar
I am confused.
Yes, the engine keeps getting faster with the same piston, and sleeve. I changed the connecting rod at 2.5 gallons, and 5 gallons. I did not clean the carbon off of the piston, I just wipe it off with a mcrofiber towel with no solvents, or abrasives. So far the engine has used 3 rods, and I did not replace the bearings once. I have actually used this engine for a dyno mule, and have a lot of dyno runs on the engine. FYI dyno pulls are much harder on the engine than in car running.
The only reason the engine would not last this long is from low quality fuel, or improper break in.
In trying to blow up the RBM3 we can not. I am sure if I revved the engine with no load long enough it would break, but under our extreme abuse the engines have all performed perfectly. We have had the engine temperatures above 375 F. with no problems.
I can not stress enough how important high quality fuel is. I have seen perfect engines have no chance due to cheap fuel. It is sad to see a $500+ engine burn up due to low quality fuel.
With a high quality fuel, and a proper break in the engine should last for an entire season. I will never go to a race without 3 engines that are ready to race just for myself. I rarely ever touch my backup engines. I can almost bet that most of the fast guys have a couple of engines ready to go at all times.
With some of the other engines out there, you will need more than one engine for a race. Not the RBM3.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
