Like Tree13Likes
Murnan Modified Motors
Old 09-14-2009, 10:21 PM
  #2326
grub's Avatar
gidday has anyone had a problem with the rbm3 front bearing
mine has side movment after 3 liters of fuel
i used the murnan break in bench meathod
grub is offline
Old 09-16-2009, 05:21 PM
  #2327
Originally Posted by Grinder
The stock 35+21 has more top end, and less bottom end than the Cordoba engine. Modified they perform the same.
The Flash has more midrange, and more peak HP than the 35+21, and Cordoba. The Flash has slightly less torque than the 35+21, but more peak HP.
The best bang for the $ is the Picco P9R, and the 35+21. The Picco is cheaper, but it will not last like the Novarossi. The Novarossi is also easier to tune when near the performance limit.
How does the bang for the buck P9R compare power wise to the 35+21. Are Are the engines very close in tq/rpm? I understand the Picco won't last nearly as long, but I only have a 1 ounce tank in my Pro-mod and am looking for something much stronger if theres is for next season after running the Picco. Can you post he numbers for your modded versions for comparison.
Also, is your standard mod $150 and drag spec $200.
OutlawIGT2 is offline
Old 09-16-2009, 06:30 PM
  #2328
RCAKid's Avatar
no problems with mine and i got well over a gallon. i have 7 qualis at the nats a 30 min semi final and a 1 hour final on my RbM3 and it is still perfect what fuel are you running?
RCAKid is offline
Old 09-17-2009, 06:28 AM
  #2329
Grinder's Avatar
The P9R will hang with the Novarossi on a small track. The Novarossi will have more top speed than the Picco. For 132 ft. the Picco will be good. What numbers do you want to see?
The standard modification is $150, and the drag modification is $250. The drag mod includes very high quality ceramic bearings, and extra work.
Grinder is offline
Old 09-17-2009, 10:24 AM
  #2330
Do you list the high quality ceramic bearing for purchase?
sheeley is offline
Old 09-17-2009, 11:30 AM
  #2331
Grinder's Avatar
No problems yet. If the engine gives you any trouble let me know.
Grinder is offline
Old 09-17-2009, 11:57 AM
  #2332
impalabob64's Avatar
Default MM RB M3
Just dropped this monster in my G4RS 09 ,thumps up to Uriah insane power..Thanks Uriah, keep up the good work my friend, from your #1 pitman.
impalabob64 is offline
Old 09-17-2009, 02:40 PM
  #2333
The Picco has been good so far, but your MM drag mod 35+21 may give me a slight edge if it has the the power to justify the price difference.
I found this info from one of your earlier posts reading through the thread. If you have the same info on the P9R, that would be great to help me see the power under the curve. There was a graph of the actual pull, but I didn't copy. Thanks
Originally Posted by Grinder;4419703
Stock 35+21
HP = 2.50
Tq = 79.18
MM35+21
HP = 2.85
Tq = 81.38
Old 09-18-2009, 08:08 AM
  #2334
Grinder's Avatar
Stock 35+21
HP = 2.50
Tq = 79.18
MM35+21
HP = 2.85
Tq = 81.38
Not sure where you got those #'s. Here are some dyno sheets of the 35+21vsMod, and FlashvsMod that I did recently.
Grinder is offline
Old 09-18-2009, 11:47 AM
  #2335
No problems with my RBM3....over a gallon thru it with a new conrod.....tons of power, thanks again Uriah!
cdub1 is offline
Old 09-18-2009, 12:19 PM
  #2336
@Uriah,
how would you compare a Nova S21WCS09 against a 35+21? The little Nova carries an attractive price tag
2nd question: Would you personally rather pick a MM Cordoba or a MM 35+21? The price is the same and after your mods power output should be the same as well. Should I choose just by cooling head color or are their any other important differences?
Many thanks and best regards,
Stefan
fulcrum2 is offline
Old 09-18-2009, 03:38 PM
  #2337
From one of your older posts.. I went back many pages and the mod was done in 08'. I see you have the engines locked in a little better now.
Any chance of getting the Picco P9R numbers to compare to the Nova Flash/35+21? Decisions.....decisions.....
Thanks again.
Old 09-18-2009, 05:49 PM
  #2338
I need help with my murnan modified m353r. How can i tell if my motor is the tuned or modified version? there's no writing on the box that says so. please help. btw, this is brand spankin new, if that helps. inside the box has extra needle. if i open the backplate, would i be able to tell? please help, thanks.
jun_808 is offline
Old 09-18-2009, 05:57 PM
  #2339
wingracer's Avatar
Trader Rating: 24 (100%+)
Interesting that while the Flash has a bit more peak power, it looks like the 35+21 has a LOT more area under the curve. Especially under 35k.
wingracer is offline
Old 09-19-2009, 06:14 AM
  #2340
Grinder's Avatar
The way to tell is to look at the timing in the crankshaft. There will be modification to the crankshaft timing intake window on the modified version. The sleeve is also not modified on the tuned, only on the modified version. Look for the teardrop cuts on the transfer ports on the modified version. The tuned has a stock looking sleeve.
Grinder is offline
