Maximising engine characteristics.
#61
Again,from BDC:
Transfer closes:65 (aha!)
Exhaust closes:89.
Inlet opens:37 after BDC
Inlet closes:65 after TDC
How does it look now?
NR P5 mash up(unknown crank)
Transfer closes:70
Exhaust closes:91.
Inlet closes:61 after TDC
RB S5 mash up(cs sport sleeve s5 crank)
Transfer closes:64
Exhaust closes:84.
Inlet opens:34 after BDC
Inlet closes:47 after TDC
Exhaust closes:89.
Transfer closes:70
Exhaust closes:91.
Transfer closes:64
Exhaust closes:84.
#63
Yes, the P5 seems very strange as well, never seen such high numbers on any of those... Maybe one of the Nova gurus can shim in.
That's why I like to measure myself, some have trouble getting it right.
#65
Novarossi transfer ports are always 65 or lower, only some modifiers will use 66 or even 67 (works good with onroad)
70 and 91 on the ports looks like a higher placed sleeve or maybe a domed piston in the sleeve made for a flat piston. Go is basically a copy of a Novarossi so I would expect no differences, but who knows...
#66
The single exhaust also makes a slight differens.
#67
I have one idea. How about making the oil rings wider now that they are worn? If the blade is strong enough to push the metal to the sides, like ploughing.
The P5 is already shot so why not try this? For science.
#68
They do something but w/o it is not the end of the world. I have seen many .12 competition engine w/o the rings.
#70
One thing I haven't seen discussed much in this thread is in regard to the crank - namely the size of the bore of the crank. I've had discussions with a couple guys on his subject - the common consensus is the same between them. Curious what others have to say about it? How thin can the wall of the crank be to stay in one piece? Or rather - is there a correlation of the size of the crank to the size of the carb? Some have said that changes to the crankshaft are half to three-quarters of what improves an engine.. Thoughts?
I have some books on the list to buy since the library cannot get them, but some of these details I doubt would be contained in a book. :yup:
#71
Hello NitroVein and Friends,
This might not be relevant with the Engine Timing Subject.
I just want to share my knowledge about basic mathematic calculation sequence.
30Tooth mention that,
360-89x2 = 182
360-144x2 = 72
As far as I know, 30Tooth calculation is correct because multiplication and division will calculated first before addition and deduction.
Cheers..
360-89x2 = 182
360-144x2 = 72
Cheers..
Well, 360-89=271x2=542
And, 360-144=216x2=432
Time to change the batteries in you calculator..?
The site Roelof posted a link to uses BDC as point zero, as most do.
(That is, if it says for instance 130 degrees of transfer timing, then it's the total opening duration! So it's 65 degrees of either side of BDC.)
So if you have an engine with 178 degrees of exhaust duration and 72 degrees of transfer duration, you have one seriously strange engine... That would come to 53 degrees of blowdown!!
There are some books that you might want to read that can help you clear up most of your problems.
#72
360-89x2 = 182
360-144x2 = 72
Cheers..
360-89x2 = 182
360-144x2 = 72
Cheers..
#73
I haven't seen anything posted or published in regard to what the crankcase pressure levels are in a small two-stroke glow engine are. I have an engine that has a pressure tap installed in the backplate that I can connect a gauge to. I'd be curious to know how crankcase pressure is affected (if it even is affected) by boring the crankshaft to allow better breathing and also altering the rotary valve timing.
It's too bad most of the books I've found online dealing with two-stroke engines don't deal with rotary valve engines like our tiny toy engines. All dealt with motorcycle and go-kart engines.
#74
360-89x2 = 182
360-144x2 = 72
Cheers..
360-89x2 = 182
360-144x2 = 72
Cheers..
Most of my math is adapted for calculating in my head instead of on paper, my teachers might had a good point in that you should do as the rest.
#75
With good materials a huge bore is possible. We have played with 9.5mm on a 12mm crankshaft. Novarossi went from 14 tot 14.5mm because of the larger bore (10.5~ 11mm) and less hussle with expensive materials and hardening.
