VP Powermaster Fuel.
#19
Fuel
Ok. ifinally did a little testing on the fuel. I mixed a quart of 20% and a quart of 30% together and added about an ounce of castor oil. I put it in a rtr duratrax buggy from the hobby shop that was brand new out of the box. They wanted me to give it a shakedown to see if it would be a good connection between the traxxas trucks and a buggy.
What I noticed. It had the smoothest idle I have seen in a long time. It reminds me of the old powermaster fuel in how it runs. very nice. I will be trying it out in my race buggy soon and give a little feedback.
#20
#21
Huh
Well, the beauty of the system is I can do whatever I want. What are you the fuel police. I ran it in my Mugen buggy today and I didn't even have to adjust the engine coming from Byrons. I still need to go on to the track and run it some more, but first impressions are great.
#22
I am no police but adding oil is done with many bad fuels. How opjective is your test by changing the fuel with adding extra oil?
#24
Ok which CASTOR OIL DO I ADD TO BRING my VP 30% that is 9% up to 10% or 11%
This
Baker's Grade AA Castor Oil
http://www.sigmfg.com/IndexText/SIGCO001.html
Klotz BeNOL 2-Stroke Castor Oil Pint
http://www3.towerhobbies.com/cgi-bin...oi%3C%2Fb%3Els
This
#25
This
This
#26
all they have local is VP
Bluethunder
Traxxas fuel
and Morgan OMEGA
I would like to get more of the Morgan Siderwinder V2 Clear.
Thank you for clearing this up for us.
#27
If a fuel had full synthetic, I would automatically add castor.. Wish companies would indicate their oil percentage on their bottles.. I would rather have a well lube engine then a engine with poor lubricant running balls to the wall..
#28
VP definitely has some castor in it.....All engines I get back here using VP usually have substantial amounts of varnish on the inside...... So there is definitely some castor.....
#29
Buddy found this
http://www.controlchat.com/castor-oil-vs-synthetic-oil/
Why use Castor oil?
Castor oil has been used as a lubricant for decades. Its chemical structure allows it to polymerise at high temperatures to form a sticky wax type material often referred as castor varnish. This wax still has lubricating properties. In the event of oil starvation the wax still separates the metal surfaces for a short time.
Why use synthetic oil?
Synthetic oils typically offer high film strength without the wax formation. Wax formation can be undesirable in ringed engines where the wax build up can result in ring sticking which will lead to a ring failure and subsequent engine failure. Synthetic oils also tend to keep the insides of the engines cleaner which results in more consistent combustion.
Why use Castor oil?
#30
Frequently Asked Questions
http://www.osengines.com/faq/faq-q663.html
Castor oil has been replaced in most fuels by some kind of synthetic oil. The synthetic oils used in model fuels are basically synthetic versions of castor oil. The synthetic oils are used because they are: 1) less expensive than castor oil; 2) less gummy than castor oil; and 3) leave less mess on the model than castor oil. They are not "better" oils, but oils with different characteristics that are highly desirable. For "problem" engines, a fuel with some castor is highly desired, because it is actually a better lubricant at the operating temperatures a model engine can generate.
