crankshaft extension please help!!!!!
i just bought a two-speed transmission for my xtm xst truggy..the motor that im using is a mega zx.21. THE CRANKSHAFT IS TOO SHORT AND IT WONT MAKE IT TO THE END OF THE TWO SPEED CLUTCH BELL. IS WILL ONLY MAKE IT PAST THE FIRST. DOES ANYBODY KNOW OF ANY CUSTOM SOLUTIONS TO THIS PROBLEM SINCE THEY SONT MAKE A TWO SPEED EXTENSION???
If not ofna makes crank extenders , check it out
YES THe bearings sit it it but the shaft wont make t to the 2nd bearing and on top of that how will i keep the clutch bell on??
Will i be able to put the bearings over that piece??
Yep, the extender is the same size as the crank and it works pefectly.
thanks everyone for the help
i installed the two speed and know i dont know if it is shifting...i cant tell...what is a good starting point for me to set the screw for the shifting
