Team Magic G4
I have to say i have never ever stripped a gear in my G4's.......YET
ok i just bought a mongoose g4 evo from rd logics and i would appreciate any info and or tips on getting this car up and running any set ups and tips to improve the car i am planning to run a sirio .12 motor which tune pipe would you suggest i use thanks and hope to run nitro on road in the bass pro series race in november
set ups
its on the way (ebay)i was just looking for a general parking lot set up for a unprepared surface on foams ,i am looking to start racing a bass pro series up in jackson ms. and maybe try to make a forgas series race .so any suggestions would be greatly appreciated
Pm me your email adress and i will send you the G4s manual. It has the basic set up in there with set up sheets. Should be a good starting point
What wheel base are you guys running? I just measured 260mm but not sure if it's shorter or longer to what you guys use. It's just a starting point for a small track. Any help/tips appreciated.
We run the rear arms all the way forward,( 258mm) haven't really experimented with the front yet.
set ups
any one know where i can find some online sites that will have some set up for the g4 evo either team drivers or other drivers set ups,thanks
I ran the shortest setting and I don't think that I will ever look back. The car did every thing that I asked it to.
Could someone please give me a starting set up for a G4+, I suppose it's similar to a G4rs.....if you run the 4mm chassis
It's just feeling very stiff and heavy and it's not yet complete so i was wondering what i can do to compensate for having hardly/none chassis flex
G4s - spring setting
Good to see all G4 TM fan and driver. I new here and nw running with G4S. four year ago, this car so so popular at my country but i think now im the only one running this car at my local track. Need some advice from the expert out there.
I dont have much choice on spring setting for this car coz the shop does have much spare part for the moment, bt im still like to run this car... and advice for any spring that i can use for this G4S.
New with TM G4S
guys
I need help. Desperately ... I am getting more and more frustrated and there is nobody to help me. Nobody at our track is running a G4 anymore, everyone has the NT1 or RRR ... so I cant copy setup of somebody else.
The car handles terribly ... it slides ans is twitchy ... I struggle driving it and I feel like I am all over the place when Im controlling it. On the straight, every single car overetakes me ...
I dont know where to start so please feel free to ask any questions that I can try and answer that will hopefully help you get a picture of what stage the car is in and recommended changes.
cheers
cheers
Same to me also, i think im alone running G4S now at my area, most people was changes to NT!, MTX4R and RRR. Need some setup adive to running this car.
it'll be a good idea if you could post yr setup and also what type of track you're running at...
http://www.cmldistribution.co.uk/tea...ter=0000002716
It says G4+, but if you see the dates they are about the time the Evo was in action. There's two for foam and two for rubber.
AFM
Here:
AFM
AFM
Has anyone got a set up for a G4+ or a link to one???
Cheers
