Team Magic G4
#3542
Clutch Nuts.
Just while I'm on,
Can I ask you all..............
Has anyone come across a different kind of clutch nut?
I'm talking about the last one you put on, which adjust's the clutch spring.
I'm getting asked this question from a concerned G4s owner who seams to have one which is totally different to the stock item.
Thanks for your input.
Menace
Menace
#3543
Originally Posted by itchy b
You can get clutch nut tools to make the job far easier!
Mugen and Kyosho both make the same type of tool
#3544
clutch nut
have this arguement between my frenz, the clutch nut, as per the manual, it shows that the clutch nut with a little protuting part facing the clutch bell, but all my other frenz argued with me that i have installed it upside down. i showed them the manual, they even said that its a misprint!!!!
#3545
#3546
I thought the clutch nut looked upside down as well. When I first built it, using the orange spring, I wound it down to get 2 threads showing as the manual states but it was really tight. I didn't use a clutch tool, just a pair of circlip pliers.
Anyway, on its first run the clutch wouldn't even engage. I pulled it out and backed it off until I had about .5 of the thread showing and it has seemed OK.
Still, I always thought the nut was upside down but followed the instructions - I'm very new at nitro cars so had no real experience to draw on.
#3548
hey kodak wat pipe is on ur car in the pics just curious looks like a sage
#3549
Its all Good on the k-factory site as someone mentioned before it faces up away from the spring
7. Install the clutch shoe silver spring retainer, spring and nut. Install the nut with the step facing away from the spring. Tighten the nut down until you have 2 threads showing at the end of the flywheel nut. This is where you will start for spring adjustment.
#3551
#3552
must make sure that its suitable for G4S, coz previously i got one, and its not usable at all as the 2 pins are way too short to lock our G4S, sold it to a frenz using mugen car.
#3553
I just checked the G4 Evo manual and it has the same part with the protrusion also facing the end bell. I took the old centax clutch off a spare Nova I had and the protrusion does not actually fit inside the clutch spring. It seems then that the protrusion facing the end bell and away from the spring is correct.
#3554
The orange clutch spring is an upgrade. It's use is not covered in the manual. The setting in the manual is for the red clutch spring. Applying the same settings from the red to the orange to the yellow and to the black will yield different results - which of course is why we buy these extra parts to tune the setup of the clutch.
Think of it like using a Mack truck pressure plate on a Mini. The setup will be different because the spring weight is different.
With the black spring for example I use a very narrow clutch gap and not much of the thread showing, but I don't use any weights in the shoes either.
If you have a piece of string and swing it above your head, you would need to swing it much faster to make it extend straight, than if that piece of string had a weight tied to the end of it.
Cheers,
Mike.
Cheers,
Mike.
