Team Magic G4
#3316
the notch is usually on the exhaust side.
Engine look very impressive.
#3317
can i know how much GR engine
#3318
anyone try kyosho t.shimo pipes,compare to 2630 which one better,i using BRB max,os speed ,thx
#3319
GR racing will release stock modified, full modified, Team version modified.
my red engine is Team version modified + matched sleeve piston set.
my engine price is about 400~450 US dollar.
#3320
Originally Posted by gansei
exact price is not settled.
could u show some more pic of your front end and the way u used the wider bottom bumper support
did u use the lola rtr lola bumper support
paul
#3321
Originally Posted by Gascar 24
hey gansei
paul
paul
i will take a picture later (now i am going to circuit to break in new engine)
#3323
model flight
thanks man
have fun with the engine
im racing my first pro tourer meet tommorrow
bit nervous really
but will be happy to finsh all my qualifiers and make the final i hope
paul
bit nervous really
paul
#3324
Wow beautiful avatars
#3325
Originally Posted by shano
Hey guys just called model flight to see what g4s parts they have and they told me tht they had nothing in stock it all has to be ordered by the customer.NOT HAPPY
#3326
Clutch question
Hi guys. I think i am finally understanding the clutch gap and end play but i do have a question.
Say i remove a shim from between the outer thrust bearing washer and the screw collet should i put that shim in front of the flywheel nut so the end play stays the same?
If you dont the endplay is larger?
THanks
THanks
#3327
Cheers,
Mike.
#3328
THanks
THanks
Cheers,
Mike.
