Mugen MTX-3
I just saw you dropped your price, I would be interested, but I already have 5 nova based engines. Good luck and if you don't sell it, you will probably get at least that much on ebay as long as you provide a picture or two.
Re: Re: Re: Re: Re: Re: Re: gear ratio?
Originally posted by Taylor-Racing
OK, seriously then. The 0.8M gears are more efficient but I wouldn't be expecting to find anything difinative and measureable in lap times.
This was suggested to me by someone and my own experiences would suggest this is a possiblility.
DC
Front roll center is lowered which gives more front traction
mtx3 is a top competitor
for the past few years i have driven a gt4 and ws satisfied with the results...unitl i drove a mtx3...idrove my friends car at my local track... then purchased the mtx3 on monday practiced and tested the car on wednesday the rest of teh week it rained so practice and final set up was only one day...i went to nercar final and placed 1st in the A main....i practice in the controlled practice prior to the race and that was all...the car is mint...
krx
buy a mugen it wont let you down
krx
0.8 gears
i see that the topic i started has no real answer across the boards, i see that the mugen drivers use them and u can see this your self if u look at a setup sheet from mugen racings site. both collins and swauger have them on their sheets, thats good enough for me.
RD Turbo II gasket
is there any of you running a RD Turbo outlaw II pipe ? what kind of gasket are you using ? i am asking because i am having problem with the leakage as i noticed the turbo II exhust port reqires a larger one or it will leak like hell i ve tried the .21s but it does not fit..any idea ?
MTX 3 prospec
Hi anyone interested in a brand new Mugen MTX 3 prospec built never run with foams and digital hi-tec servos? make me an offer
Novarossi JP Black NSR 5 port
Novarossi Stainless pipe and headder combo
email or pm thanks
email or pm thanks
BIG NEWS x 2!
Well, one of the big news is that the new Kyosho VoneRRR is currently kickin' a$$ in Brazil.
Second is that there is news that Mugen is currently testing the new MTX-4(if it even called that).
So, my question to you MTX-3 fans out there is......
What changes/improvements do you want on the MTX-4 over the MTX-3?
Maybe Mugen will hear us.
Me, I want....
Centralized fuel tank with clearances for the throttle servo horn ala MRX-4.
Adjustable front roll center.
One piece rear shock tower/body post mount.
Vertical rear inner camber link mount
More upper shock mounting positions front and rear(I race rubber).
Top load front/rear diffs.
Single or lighter brake disc and lighter brake hub.
Lighter mid/two-speed pulley hubs.
Lighter/smaller diffs and two speed assembly.
Standard fifth body post.
Easy change ackerman adjustments.
And dare I say, laydown throttle servo like the RRR and a lower radio deck.
The shock/steering/sway bar pivot balls could be lighter too or hard anodized aluminum like KFactory's.
BTW, I still think that the MTX-3 is fully capable of giving the RRR some stiff competition despite the MTX-3's age. But since people in the know say that Mugen is currently developing the MTX-4, I say give them all the input that we can(again, IF they are listening).
What do you guys want?
Me, I want....
Yes, all that . . . plus, I want....
Better free roll - soft belts like V-One RR.
Ability to get the clutch bell off without loosening the engine.
More durable 2-speed clutch.
Single screw adjustment for front droop.
19T first Gear (0.8M).
A decent belt tensioner.
4mm engine mount screws.
3mm longer front shock shafts.
. . . . . not much to ask, is it.
Re: BIG NEWS x 2!
Me, I want....
Me, I want....
Taylor-Racing Ability to get the clutch bell off without loosening the engine..
Originally posted by gonzoY5
The trick is to make sure the inside bearing doesn't come along with the clutch bell and you should be able to remove it without loosening the engine. I usually just use a 1.5 to push the bearing back while I'm removing the bell. Good luck.
pro drivers list your best mtx3 setups w/conditions
hyper/mtx ?
hi..i've taken a close look at the driver and the car...and anybody can give a hint whats goin on ..?
another one
