Mugen MTX-3
#2911
Originally posted by Corse-R
Any disk brake you get until it doesn't warp, have a decent weight and good price is good. Sent one unit of the enetti disk brake to Manti and seemed that he liked really. I use them on my MRX and on the MTX without no problems and the MRX goes by the third set of brake pads with the same disk.
#2912
Re: Solid Axial
Originally posted by Data
just want to know how many people want to use a one piece solid axial on their MTX-3. maybe we can get together and have some made.
#2913
Re: Solid Axial
[QUOTE]Originally posted by Manticore
the 3 racing rotors made of soft chrome iron (not steel) the holes on the rotor wear fast after runs !![QUOTE]
Anthony, I believe you!!! But like I said, I have a set on my MRX-3 and haven't noticed any wear. I admit I rarely use the breaks, but so far it's holding up well.
#2914
any one tried Kfactory stuff??
#2915
i have kfactory battery holder and its really top quality
unfortunatly it didnt fit on the mugen 4mm chassis without modification that sucked
the part in the front that the screws go into required the chassis to be shaved some
but i was pleased with the end result
#2916
jason
how can i reach you need some imfo
#2917
jason r u going to dougs this sat
nelly
nelly
#2918
thanx for all the help, cant wait to get this car.. just gotta sell my current ride to fund the project.
that rotor looks awesome... does it work as good as it looks ?
#2919
Re: Re: Solid Axial
Originally posted by czotalis
im in
im in
#2920
help pls
im still building this car and i noticed on STEP 7 that u can have ur car with front one way or front differential ? what are u guys using?
Also the front/rear driveshafts come out once I turn the front wheels/ rear wheels. Someone said here to put o-rings. But where?
what bag can I find the rubber tip on the antenna tube?
Are there any other manufacturer selling metal anti roll bar holder because the stocks are made of plastic?
thnx
thnx
#2921
Originally posted by penggoy
help pls
thnx
help pls
thnx
With the driveshafts coming out you may just not have the kingpins screwed in enough but all putting a o-ring on the diff side does get rid of excessive play.
Pretty sure it doesnt come with a rubber tip for the antenna tube use a bit of fuel line that does the trick also.
Kawaharra and rdlogics make the metal roll over bar.
#2922
Most guys like running a one way for big tracks and tight small tracks they run a diff. But for the diff you will need to buy the gears and other stuff needed to complete it. You can bring the track width in to stop the dog bones from coming out, or put small peices of fuel line in the outdrives and in the axle. Put the o ring in the outdrive for the one way. They do not include a black antenna cap for the antenna. Rd logics has the rear anti roll bar bracket in aluminum. Here is the link to it http://rdlogics.com/store/P_119.htm
#2923
many many thnx guys. im still building it so if I have troubles i'll post them here again.
#2925
Recent race was the Speedline race.
