Mugen MTX-3
#2506
i have the RR Hard Centax Clutch Spring, i am wondering if it can fits on the MTX-3 ?
IS the stock MTX-3 centax clutch spring harder than the RR Hard Clutch Spring?
cheers
cheers
#2507
i am going to take a good long hard look at my car
i may have dual rate too high and the servo saver spring too tight
either way adjustments are needed
if the servo saver had given way it may have been enough to save the universal
i gotta check the dual rate i think mine is still under 100% but if i can go less i will
#2508
i think its because the servo saver is TOO LOOSE. also the steering rate will not affect it. try this test. switch on radio gear leave in center posistion and turn the wheels full lock now hold and turn the inside wheel, you will feel the cv go tight. now if you clip a board on the track and this happens the shaft will snap. the servo saver lets the wheels go further than the lock on the radio!
#2509
AIP solid axle adaptors are in!
Limited quantity!
JustRC
Limited quantity!
JustRC
#2510
hello guys,
I just finished assembling my new MTX-3 and do it accordingly as pointed out here in this thread all those minor adjustment s. I also change few option parts which i think will help improve the car i.e.:-
1. lite alum upperdeck centre support
2. alum 3d machined rear brace
3. lite alum front sway bar mount
4. alum front belt centre block
5. uni-joints front
6. alum wheels hex
7. mugen-seiki teflon brake pad
I am really impressed wih the new design of this car especially the rear arm and the streering ackerman. Hopefully I'll be able to test out the car this evening.
Can anyone point out where else I can download or view other drivers' setup sheet or setting? I cant seems to find it anywhere else except for mugenracing.com..
5. uni-joints front
6. alum wheels hex
#2511
Originally posted by kaikiok
hello guys,
5. uni-joints front
6. alum wheels hex
hello guys,
5. uni-joints front
6. alum wheels hex
#2512
Manti,
have you got your Mugen chassis fixed up? its getting bored without pics...
#2513
Originally posted by RClover
Manti,
Manti,
#2515
wow...this is cool...as light as the stock chassis?
#2516
I believe it is lighter then stock, but I can not confirm this because I do not have a scale.
Bryan N.
Bryan N.
#2517
Bryan N.
Bryan N.
#2518
when will the neggative diff for the mtx3 come in.i would also like to see a front neggative diff also.since at high speeds the diffs lock up and act like a solid axle,i would like to run a neggative diff f/r.i ran a solid axle f/r setup on my old yokomo gt4 and it was great on the straights,the free roll and braking was excelent.and since the neggative diff has got best of both worlds i would like to try that setup.
#2519
Originally posted by Manticore
not yet, i am still busying with my M1RR !
get a new life with MTX-3 before MTX-4 is out...
#2520
cheers
cheers
