Mugen MTX-3
I've been told that the associated diff lube is too thin, several guys told me to go with the thickest mugen grease but they were not able to give me the # number.
Originally Posted by Dreamlinee
Hi Everyone, I'm new to the form and I have a question regarding the Kawahara negative diff for the Meugen MTX-3. My question is: How do you put the rear shock tower back on the rear bulkhead after the Kawahara negative is being installed when the diff's body is so big? Do you needs some kind of spacer to raised the rear shock tower? Thanks, Bruce
Maybe somebody else has done something diferent.
Jose
Originally Posted by freefallmarine
Hey John, I picked up some greens and red bsr's. Thats all they had, good for T&T? Ill try some take off's too I guess. P.S. Time to change that avitar....hehe...
If the track is blown off and there is decent traction (for concrete), then go with REDS on all four and you'll have better steering response. REDS are the softest.
Avitar - That is number 26 on my todo list. Plus I still have an R40 so I am not totally out of date.
Originally Posted by afm
I totally agree with you. We used to race with BSR's, but unfortunately they are not legal sized for sanctioned races, and we had to search for something else...that is how we ended with PMT.....I wised BSR would build a legal sized tyre...I'd go back to them even it they are pricey.
AFM
AFM
I'll have to check out these PMTs - gotta link?
Originally Posted by JAG Racing
Hi AFM - right, they are not ROAR legal but I think it is becuase of the definition of "capped" and not really the size. I beleive ROAR dictates that the insert cannot be attached to the rim ( i.e. glued as in capped tires).
Before the BSR's we used to race with Jaco pre-capped tires...also exelent tires, but they discontinued manufacture, and those were 26mm.
PMT's web site is www.pmt-tyres.it
We ( www.gppmodelracing.com ) distribute PMT down here and we sell the set of four slicks premounted in white BBS style rims at U$D 40.00 set. (50 shore fronts, 45 shore rears).
AFM
Kawaharra????
Hi Guys, we are racing MTX-3's at our club now and are in search of all the best bits. Can you guys give me some pointers as to where you buy the Kawaharra hop ups as most of the sites i visit have very limited selection of parts. Is there somewhere that we can order stuff over the internet?
Thanks Slotmachine, that's where i buy most of my gear from now but they seem to be limited in their Kawaharra stock compared to what is available for the cars. I have been trying a bit of the k-factory parts which seen to be pretty good as well.
Thanks dude, that's what i'm after. prices look to be a bit dearer but hey atleast they have them.
Glad I could help!
this is what i use for everything in the car that needs grease (cvd, thrust bearing, oneway, .....)
http://rc-mushroom.com/product_info....oducts_id=2627
what will change if i put the prospec gearing in my stock mtx3?
