Kyosho Inferno GT, GT2 Race Spec
#886
If you're a racer , you may want to check out what many have done with that car and the evolva gears. It makes for options you may want. That flat chassis will be good until 2015 when the roar rule package will make it illegal.
#889
This one is purely a basher. I am building another gt2 just to race.
#891
Hpi clutch bell is on with 18 and 22t pinions. Jp2 pipe and lrp.28. Hahaha
#892
Does anyone know if the SWEEP GT 1/8 Body set P1L SD0002 will fit on a GT2? I think not cause of the lenght? Thanks!
#893
Maybe you can cut the holes for the rear tires 3cm further back but i dont know how it will look like .
#894
Cost of SNR chassis?
#895
EDIT : Found TEAM C GT2 Body Set 1/8 F599 That would be good i guess
#896
I'm getting some serious front end shake during braking. Is it time for cvd's up front? New bearings probably too. I have a ton of hub play.
#897
The car is fully devolped now...this pic shows the updated top plate from the MP777 and STR, new Kyosho fuel splash shield, mp777 WC steering with ackerman ! Also I installed the "B" blocks upper and lower up front (thanks to a tip from (scarryJerry) which will help lower the caster angle a bit ! This car is like day and night compared to it's original RTR form...I hate to say but the only thing wasnt replaced are the front and rear suspension assemblies !!....If you want to build a competitive racecar it will be cheaper starting off with an MP777WC roller !! I will be running the Ipanema warrior body to help with steering turn in ....hunting for snakes now.. : )
#898
looking good.....
#899
#900
Where can i find an aluminum trans mount?
