Kyosho v-one rrr
#5851
Originally Posted by B4
Have you tested the Serpent tool, because I have and it does fit.
#5852
Originally Posted by jeffreylin
The best way to allow your rear to use 0 degree offset tires is to change the rear universals to VSW007 and not worry about the hexes and the pillow ball screws.
I want to give this a try. I'm tired of using 2mm offset wheels.
#5854
Originally Posted by maskedrider
VSW007 is for RRR ??
how come i couldn't find in our manual ??
Thanks.
#5855
Hope you guys find these useful, courtesy of NiMo from 3Hobby.
#5856
Wow, a handly little chart. Thanks for posting. But what's the diff between rear hubs VZ202 and VZ006?
#5857
#5858
Can somebody explain to me the the tire information on the last 2 charts? I don't understand what 26mm 0mm, 30mm 2mm & 30mm 0mm is telling me. Is 26,0 for someone using front tires in the rear? Why is 30,2 under the heading of 0 offset and 30,0 under the 2mm offest heading?
That chart is bad a$$.
I understand that the VZ202 is the stock bearing block for the RRR but what is the actual difference?
#5859
#5860
Originally Posted by joemugen
my interpretation is that they are saying the actual wheel has a 2mm offset and the hub has a 0mm offset.
Am I to understand that the difference between VSW007 and VSW015 is the wheel shaft and not the length of the drive shaft? I'm not crystal clear on this either. Would using the VSW006 be the same as the stock swing shaft except with a shaft that's 2mm longer or are we trying to just move the wheel out so a 0 offset wheel doesn't get to close to the bearing block?
Sorry for all the questions... I just want to understand this before I order the parts.
#5861
That makes sense.
DIFFERENCE is that VSW007 has got a 2mm offset wheel shaft (VZW055-02), and VSW015 has got 0mm offset wheel shaft (VZW054-02).
#5862
Saying that, VSW007 has got longer axles, of which the hole is 2mm further out, this facilitates the use of 0mm offset wheel. A 2mm washer is to be added BEHIND the hex if VSW007 is used.
On VSW006, it has the same overall length, just a different combination -52mm shaft (VSW006-01), and a 0mm offset wheel shaft (VZW054-02).
#5863
Now things are becoming more clear. I could not figure out how the VSW007 was going to help. In lieu of the 2mm washer could a different hex be used? If I tried the VSW006, would a 0 offset wheel be too close to the bearing block?
#5865
Hope these pics are clear enough, this is how the spacer works on the VSW007. Without the spacer, the shaft will be left sliding in and out of the rear hub. On an alternative wheel hex, 3Racing makes one with 1mm offset, still does not quite work without a spacer. The spacer is doing the job good, no worries; I've used both 0 offset and 2mm offset wheels on the VSW007, no problems at all.
