Capricorn LAB-C01
#1651
yes xray fit directly.
#1652
My car was exceptionally good the entire weekend with me having the second fastest lap time during practice and the fastest lap time during qualifying.
I ended up qualifying third behind Daan Jacobs and Pedro Rombouts and just in front of Maxim Claes.
This is the setup I was using, the car hasn't been this good before:
http://dsmotorsport.nl/http://dsmoto...hen_NK2012.pdf
Thanks for your setup sheets. I have been trying to figure out what the advantage is of shimming the wheelhubs outside; instead of adjusting the pivot balls, and we never use shims there since we don't know. Is it just to enable quick changes to the trackwidth without having to re-adjust other settings, or is it something else?
Kindest regards,
Lars.
#1655
#1657
#1658
How many of you guys have tried running with the spool? ..... any good?
BM
BM
#1660
Hi Daan,
Kindest regards,
Lars.
Kindest regards,
Lars.
Offsetting the wheel changes the 'scrub radius' of a tire.
http://en.wikipedia.org/wiki/Scrub_radius
In Rc cars offset also has quite a big influence on the jacking forces in the front suspension. Because of the big caster angles used more offset will put more pressure on the inside tyre. Also the wheelbase difference between left and right is increased when you run more offset.
Because of this in general more front offset will give you more steering at corner entry and mid corner.
I found less off set all round will give the car faster weight transfer and makes it better through chicanes.
On the C01 I always used 0 offset all around (all shims on the inside). WIth the C02 I ended up with the stock settings, the thin hex up front and the medium one in the rear.
For a tight, technical track you might try it the other way around.
#1661
Offset is quite difficult to explain how it works, it's not for changing track width though!.
Kindest regards,
Lars.
#1662
Short wheel base setup
Tried the short wheel base setup and it did improve the car through the chicanes but still have big push going out of certain chicanes. Any recommendations?
#1664
If its just at the corner exits...... try reducing the rear toe-in a little. See if that helps.
BM
#1665
Has anyone tried these on the C 02???
http://www.capricornrc.com/capricorn...2323-large.jpg
Thanks Michael
Thanks Michael
