Kyosho Evolva
#1231
From the Kyosho Japan Site the parts available for Evolvaa 2007.I think if we buy them, then our 2005 will be 2007 version.
http://www.kyosho.com/jpn/products/rc/newparts.html
#1232
I could go through this entire Thread but perhaps some or all you experts could give me the answer I am looking for: What exactly is the difference between the 2003, 2005 and the 2007, I see the 2007 list in the post above so I guess my main question is 2003 versus 2005. The reason I ask is because I have a very nice 2003 (and a lot of parts) and I am wondering if I need to buy a new car, update, or enjoy what I have. I do have the Empire front bet tensioner.
I know the 2005 had adjustable belt tension and different gears, that is about all I know.
Is the wheelbase shorter? If so how?
As far as the gears are concerned can they be mixed and matched or must they be used as a set......and why?
Thanks in advance
Thanks in advance
#1233
OldnSlow2 -
* the front and rear bulkheads are different (they have adjustable belt tensioners and these also lower the cg of the one-way/solid axles)
* softer front sway bar
* you can adjust the wheelbase from "normal" to "short" by being able to move the lower front a-arm front and back.
Those are the major differences between the 03 and 05.
You might want to wait a bit for the 07 kits to come out. It'll cost you approx $80 to $100 to upgrade the 03 to 05, and who knows how much to go from the 05 to 07 model.
#1234
Is there a front spool (solid axle) for the evolva ?
Will it handle better with front spool ?
#1235
I find that running a spool makes the car easier to drive and my fastest lap was run using a spool.
Check http://gasrccar.com/eshop for more details.
#1236
Where can i find the Evolva 2005 WC Instruction Manual?Not the 2005
#1237
This track is just minutes away from the Nation's Capital
RC Pro Series two-day race entry form
Can be submitted at the track on race day.
Capital Classic June 6th-10th
Factory drivers already registered. 160 max. entries. Don't miss this one!
#1238
FMW104 - 2007 Evolva Conversion Kit.
See picture.
See picture.
#1240
Hey guys, I'm selling a still-in-the-bag FM427 Lola body for $30 plus shipping, obo:
http://www.rctech.net/forum/showthread.php?t=159370
#1241
Assembly help
Hi Guys
I am new to the 1/8 class and have recently purchased a Evolva 2005 edition - not the WC edition. I am busy putting the car together and now I seem to be stuck.
In one of the bags that you use to assemble the front of the car, I have 2 pulleys. One with more teeth and one with less teeth.
Now, one of these pulleys needs to go on the front tube (one way). The question is, which one
I have put the pulley with more teeth on the front one way tube - is that correct? Is the other pulley a spare?
Thanks in advance...
Acid
Acid
#1242
does anyone know when the 07 will be out in the states , also will if be worth it to wait for it or should i just get the 05 wc thanks guys
#1243
#1244
is there really that much of a differance in the 2 kits
#1245
I guess the choice on what to get depends on wether you have a 05 or not.
