Serpent 710
Originally posted by PSI Racing
Do you know if it will work with PCM?
I think it runs on FM only. I remember that the 3PM run the same HRS receiver (FM) as the 3PK while for the normal FM, it uses the R123F receiver. So I guess then that the R303FS is FM...
Originally posted by InitialD
I'm actually not sure if the R303FS runs on HRS or PCM. I'll check with the manual in the LHS.
Originally posted by markp27
Don't work - race
Don't work - race
close ups!
Re: close ups!
Re: Re: close ups!
Re: close ups!
Re: Re: close ups!
Looks good though except for the conrod. Like I mentioned, put the piston sleeve in the JP engine and turn the flywheel. Perhaps get a spare JP conrod to replace this one since it is wise to have a spare conrod anyways for the JP. Don't forget to get the circular clips too that locks the pin in the piston.
I'll have to clean the bearings - do you know what lube should be used with them?
I've got lots of those clips - serpent ones, but they should be universal, I would have thought.
try this!
Heres a idea sell the Serpent and get a Mugen ..............................What do you mean get a roap ? It was a joke I tell ya
Re: try this!
Root cause found!
D, you assumption was correct, the crankshaft is bent! It wasn't really obvious to see at the end of the crankshaft, so I screwed an extra long m3 screw into the end and then span it again - then I could see a small but significant deflection!!! Man, that Mugen must have made a one in a million hit on my crankshaft I'll try cleaning the rest of the engine to make sure nothing else major is broken, then I'll get a new crankshaft - I've got a spare conrod already
Cheers, Mark.
Cheers, Mark.
Actually just used another method to confirm the wobble: placed the tip of the crankshaft against a spray can, so the was no gap between the crankshaft and the can - then watched to see if a gap appeared as I spun the crankshaft - sure enough I could see a gap "appear" then "disapear" during the rotation
See pics below and note how small the deflection is!
Re: Root cause found!
Guess what... I knocked the bent crankshaft back to "straighten" it out with a plastic hammer. No special tool though. Just by feel and instinct. Have not run or tested it out yet.
Re: Re: Re: close ups!
