What's this transfert port is for??
Ofna Force 28 sleeve, look what's i've arrowed in red, don't understand the utility of this port.
If I am right then in the piston there are holes lining up these holes.
When the piston is comming down and building up pressue under the piston then some mixture is located right under the piston that will not easily flow into the channels but through the holes in the piston some mixture will find an easy way to the transfer port.
If there is no hole in the piston this port is open at TDC and also some mixture pushed up by the crankshaft will go through it.
Roelof is dead on. Its a shortcut to allow fuel/air trapped under the piston to have a shorter path into the ports. Usually there are holes in the piston skirt that line up with the ports.
You're right man I've remove the piston and they've windows line up with this ports.
Thank you
http://www.rctech.net/forum/nitro-ro...ro-engine.html
Good Luck,
Roger
