HPI R40 Nitro Car Forum
Originally Posted by Artificial-I
Hey guys got a quick question with the .8 2speed. I know the stock setup is a 1 and 7 pinion gear. Ive run a 0 and 6 with good results on my shorter track.
My question is I now have a 0 and a 5 pinion on the r40. Will this cause any trouble with the stock .8 spur gears? My friend believes I have changed the stock split which is going to strip 2nd.
I was under the belief that the r40 gearing is setup to be run with any pinion or spur gear without any worry of mesh.
Let me know. Also today Im going to show some video of my car with my new mugen clutch. I tuned it and ran the clutch around the driveway yesterday its amazing the difference.
When you buy these gears, you get a gear chart that shows all the different ratios between the gears. I dont think HPI would give that info in the table in you cant use them together.
What your friend could be saying is that because of a big split, you would be putting more strain on the second gear the moment it goes from fist to second.
I just orderd 2 OS .18tz and a few other goodies for my new R40, but witch pipe is currently the best fit for the car?
Yeah I figured so but just wanted to make sure. I believe the rs4-2 you had to take mind of what gears you had to run with certain spur combos. Been awhile on that one.
Yeah my split is smaller now. So it should shift with less harshness I hope. Ill have some video of it in a little.
Also those with the Hara kits is your battery running extremely close to the side belt? Im wondering if you guys are mounting the batteries sideways...I think I tried but there wasnt enough room vertically.
If anybody has any used or beat up bodies for the R40 they don't want, please PM me. Looking to run my R40 this weekend. Will pay for shipping. Thanx
does anyone know what type of battery i have to use for the hara r40 edition.....can i use the normal stick pack...or do i have to use like a 5 cell AAA batt packs?????/
thanks
Mike
thanks
Mike
Go back a couple of pages in this forum or do a search. This topic has been discussed before and you will find some photos/pictures as well.
Hi
Does Mugen mtx3 grey clutch shoes fit on the R40? I have the standard gears, not the 0.8 set. Any modification needed to make it fit?
Yes it will fit , you need to modify the holes in the shoe , basically make them larger and or further outward.
You need a 5 cell AAA hump reciever pack. You should be able to find a sanyo 1000mah pack. This seems to be the best , cheapest option around. Has a nice short rx wire too for keeping runs clean.
I'm still looking for a R40, I prefer Brand New.
http://www.rcmart.com/catalog/produc...ducts_id=16289
about $345
ok thanks for the info with the battery....umm what lipo can i fit in their instead of one of those sanyo 1000 pack...im sure i can get a lot more juice out of a lipo and lose alot of weight
hey guys...i was also wondering what kind of springs you guys used ont he car...i only could get my hands on the gold and silver sets...cuz i know the front shocks are a littler shorter....so which other springs can i use...the AE spring kit...or what?? i see pics with peopel using white springs and stuff...so im guessing the AE ones i can use..??
I beleive some people are using springs from the Proceed. I don't think you will really need any more sets of springs then the kit and the extras you have already bought. The silver are softer and the gold are harder then the kit springs. I use Black fronts and Silver rear with diffs front and back. With a solid front axle Silver front and Black rear is what AMG runs. You could also tune using shock oils and different shock pistons. The car really is pretty easy to set up for good handeling. It has a wide sweet spot.
